Life Story entry #324
Finished the EOFY books at work today. Just need to follow up a few items, but the heat is dying down now. The bosses look a little stressed after I told them the tax bill figure (BAS) :rofl: ... wonder why? :D
Now I'm going to (a late) lunch. The day's been full on. :D
hey cara...
... GET A DET!
Lol, just finished reading the chronicles of bruiser, f**king funny! I do recommend that you all read it!
haha, its a rad tale, was much be better when it was in forum lay out though. much more lols to be had.
was it for real or was it a pair of 12 year olds playing cops and robbers?
please explain
they sounded pretty legit... like in their 30s or 40s.. probably drug dealers. i can often hear drug dealers on cb scanner at work, never heard them planning a murder tho. could be some phony gangsta wannabes tho
you 2 fighting remins me of wood work in kindy, when i used to
fight this kid because i wanted the bigger hammer.
i got kicked out of that kindy. its not my fault the top of his finger got crushed, i swear!
i have just decided something.....
seeing as im currently weighing in at 98.7 kgs in my birthday suit, i have absolutely no chance in hell
of winning the go kart GP coming up.
SO
i think my aim will be set on Ruby, for being so farking cocky thinkin he is going to win.
my aim that night, is to make sure he doesnt win! while hopefully still placing higher than him....
yeah, that should make it more fun.
hehehe
I think some tossbag just tried to rip me off on eBay... won a phone off me, paid through PayPal by eCheque, probably thought I was going to send the phone off before it clears, the eCheque was meant to be cleared by sometime yesterday to tomorrow, today the eCheque status was cancelled - guessing either he didnt have the funds to pay so it failed or the scum was trying to get a free phone.
Bah what a waste of time - have to dispute and claim fees back and relist the item and wait another week until it sells again.
Who wants to buy a Sony Ericsson C510 for $250? As new approx 1 month old.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
