Life Story entry #324
Finished the EOFY books at work today. Just need to follow up a few items, but the heat is dying down now. The bosses look a little stressed after I told them the tax bill figure (BAS) :rofl: ... wonder why? :D
Now I'm going to (a late) lunch. The day's been full on. :D
hey cara...
... GET A DET!
Lol, just finished reading the chronicles of bruiser, f**king funny! I do recommend that you all read it!
haha, its a rad tale, was much be better when it was in forum lay out though. much more lols to be had.
was it for real or was it a pair of 12 year olds playing cops and robbers?
please explain
they sounded pretty legit... like in their 30s or 40s.. probably drug dealers. i can often hear drug dealers on cb scanner at work, never heard them planning a murder tho. could be some phony gangsta wannabes tho
you 2 fighting remins me of wood work in kindy, when i used to
fight this kid because i wanted the bigger hammer.
i got kicked out of that kindy. its not my fault the top of his finger got crushed, i swear!
i have just decided something.....
seeing as im currently weighing in at 98.7 kgs in my birthday suit, i have absolutely no chance in hell
of winning the go kart GP coming up.
SO
i think my aim will be set on Ruby, for being so farking cocky thinkin he is going to win.
my aim that night, is to make sure he doesnt win! while hopefully still placing higher than him....
yeah, that should make it more fun.
hehehe
I think some tossbag just tried to rip me off on eBay... won a phone off me, paid through PayPal by eCheque, probably thought I was going to send the phone off before it clears, the eCheque was meant to be cleared by sometime yesterday to tomorrow, today the eCheque status was cancelled - guessing either he didnt have the funds to pay so it failed or the scum was trying to get a free phone.
Bah what a waste of time - have to dispute and claim fees back and relist the item and wait another week until it sells again.
Who wants to buy a Sony Ericsson C510 for $250? As new approx 1 month old.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
