yeah I sorta noticed the next day.
For some reason a few of us thought weetbix and wine mixed. Also shots. Had to sleep it off the next day at a children s playground in a non-pedophile way
bahahahaha yea iv slept one off before in a random gazeebo along the espy,gotta love the loose nights and using a back pack as a pillow, boy does it get dam cold tho!
can anyone get good deals on 4wd accessories...........tryin to get a good price on some Lightforce lights
if ya can hook me up, im after 2 pairs of Lightforce 170 Strikers with Crystal Blue Spot covers
Ill see what i can do.
its all about having fun and being a wee bit competitive
lol i dont think the guys at the venue like their karts being drifted but go for it.....its only you loosing lap time and speed and momentum and then BAM...Big Bad Craigy has got ya :(
it aint how you stand by your kart
I've never been told off before :)
ive never been told off either including the 1 time i lost it trying to get it 2 far swideways :)
motivational pics
If anyone is after Motul Gear 300 75w-90w 100% synthetic gear box oil i have a 25L drum of the stuff. I'm selling it for $32 dollars per litre. In shops this goes for $43+ per L.
Let me know here or via pm if you need some.
Might give you a yell soon Luke, gearbox is well over due for fresh blood
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
