got my cooler pipes today. they look mint, andrew did an awesome job. forgot a holesaw though. :)
got a bit of wiring and a bit of cutting to do, but its almost there. will post pics when its all back together.
Awesome! He does great work, I'd love to see some pics of it now
Have fun getting the holesaw through the inner guard, i gave up with mine and attacked it with a 1/8 drill then belted it out :(
haha. if i get frustrated and give up, i can get a pneumatic drill and a tungsten hole saw at my door within a couple hours for nothin.
that he does. but im gonna make you wait. :)
might swing by when its running tomorrow.
Edited by scandyflick
ladies and gentlemen, i have two words for you;
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :yes:
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :D
scratch that. problems already. hit a little over 1bar for a second on a test drive, pulled over straight away and readjusted the controller, problem is, now it isnt boosting over 0.5 bar no matter what i do, and it hits a wall at 5k rpm. :thanks:
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
