got my cooler pipes today. they look mint, andrew did an awesome job. forgot a holesaw though. :)
got a bit of wiring and a bit of cutting to do, but its almost there. will post pics when its all back together.
Awesome! He does great work, I'd love to see some pics of it now
Have fun getting the holesaw through the inner guard, i gave up with mine and attacked it with a 1/8 drill then belted it out :(
haha. if i get frustrated and give up, i can get a pneumatic drill and a tungsten hole saw at my door within a couple hours for nothin.
that he does. but im gonna make you wait. :)
might swing by when its running tomorrow.
Edited by scandyflick
ladies and gentlemen, i have two words for you;
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :yes:
IT'S ALIVE!
started the 200 a little over 2 hours ago, tended to any leaks (there was 1), fitted the turbotech mbc (too lazy to wire in the ebc tonight), made sure the cooling system was going as it should, and put the front end back together. gonna have a shower and take it for a spin. :D
scratch that. problems already. hit a little over 1bar for a second on a test drive, pulled over straight away and readjusted the controller, problem is, now it isnt boosting over 0.5 bar no matter what i do, and it hits a wall at 5k rpm. :thanks:
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
