so u wanna take the 32 while i take the rolla?
ahahha.. but seriously.. will the stock 25 take it?
Depends how hard your going to limiter smash it lol,
Maybe an aftermarket rev limiter so you can make it a bit lower then redline so you don't do any damage?
25det loves limiter, just ask mine :P
been bouncing off it everytime it gets driven for the last year and abit. I am running microtech though and have the limiter set a couple of hundred rpm lower to keep it safe. Turbo on the other hand had enough after that long.
If i could semi drift with a rb30e and king springs, youll be fine with your setup man.
no matty, just no
when are you getting those "HOTRSX" custom plates? :P
oh come on jake, the name's gotta stick somewhere aside from there :)
those plates are reserved for thidras..........unless u want them haha :)
oh come on jake, the name's gotta stick somewhere aside from there :P
the only place im not known as twink, id like to try and keep it that way matty!
