Decided to upgrade all the belts on my Stagea. Got a complete set of Gates belts coming: timing belt, water pump, ps pump, alternator. Guess what I'm doing next weekend? :)
Shopping around online, but can't find:
air diversion plate for grille-radiator for Stagea
cold air panel for pod filter for Stagea
Anyone know of a shop, person or sheetmetal mob who has or can make them for a Stagea?
Might just make a template up using cardboard if thats how everyone else has done it.
That would be your best bet, i think i'll end up doing that to mine when i get around to it.
I saw Chad's (dstroy) set-up in his 32 and looked pretty cool, couple pieces of sheetmetal, welded together, one or two pipes running from front bumper vent, up through to under the pod, then enclose it, or even making it detatchable..
well look what i just found browsing around... lol
when one side skirt just isnt enough
http://www.skylinesaustralia.com/forums/po...192045-neww.JPG
found here:
http://www.skylinesaustralia.com/forums/Fi...99#entry4723499
found here:
Classic example of spending $$$ to make a car look worse than a bog standard car.....
Yep, can make a carbon fiber one Ruby, but not just cardboard template, actually use a mold to make it fit perfect for your exact car. just need some time to do it..lol
love this comment from adelaide now
The biggest revenue-raising fixed camera is located at the intersection of South Tce and West Tce in the city. Last year motorists caught speeding by the camera were fined a total $1,501,423.
So far this year, 73 people have died on the State's roads compared with 46 at the same time last year.
hmmmm seems the cameras dont save lives after all do they....lol
Has anyone else noticed that nearly all of the road deaths this year have been country/highway? So how are all the 50km/h speed limits, speed cameras and defect blitz's helping slow the road toll?
Perhaps Mike Joke Rann and his cronies should address the actual problems here ....
How long would that take? And what would the cost be? Interested in doing something 'different' :(
So they're claiming approx 5,900 motorists ran those lights? Thats approx 16 cars per day? I call BS.
Also, think of the number of emergency vehicles (fire/ambos) that contantly run those lights, being a major link to the south and south-west.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
