Decided to upgrade all the belts on my Stagea. Got a complete set of Gates belts coming: timing belt, water pump, ps pump, alternator. Guess what I'm doing next weekend? :)
Shopping around online, but can't find:
air diversion plate for grille-radiator for Stagea
cold air panel for pod filter for Stagea
Anyone know of a shop, person or sheetmetal mob who has or can make them for a Stagea?
Might just make a template up using cardboard if thats how everyone else has done it.
That would be your best bet, i think i'll end up doing that to mine when i get around to it.
I saw Chad's (dstroy) set-up in his 32 and looked pretty cool, couple pieces of sheetmetal, welded together, one or two pipes running from front bumper vent, up through to under the pod, then enclose it, or even making it detatchable..
well look what i just found browsing around... lol
when one side skirt just isnt enough
http://www.skylinesaustralia.com/forums/po...192045-neww.JPG
found here:
http://www.skylinesaustralia.com/forums/Fi...99#entry4723499
found here:
Classic example of spending $$$ to make a car look worse than a bog standard car.....
Yep, can make a carbon fiber one Ruby, but not just cardboard template, actually use a mold to make it fit perfect for your exact car. just need some time to do it..lol
love this comment from adelaide now
The biggest revenue-raising fixed camera is located at the intersection of South Tce and West Tce in the city. Last year motorists caught speeding by the camera were fined a total $1,501,423.
So far this year, 73 people have died on the State's roads compared with 46 at the same time last year.
hmmmm seems the cameras dont save lives after all do they....lol
Has anyone else noticed that nearly all of the road deaths this year have been country/highway? So how are all the 50km/h speed limits, speed cameras and defect blitz's helping slow the road toll?
Perhaps Mike Joke Rann and his cronies should address the actual problems here ....
How long would that take? And what would the cost be? Interested in doing something 'different' :(
So they're claiming approx 5,900 motorists ran those lights? Thats approx 16 cars per day? I call BS.
Also, think of the number of emergency vehicles (fire/ambos) that contantly run those lights, being a major link to the south and south-west.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
