anyone have some decent res pictures of skylines from car shows or private photo shoots that they dont mind me using for promotional material? Can you link to me your photo hosting site or email them to me?
Can anyone give me some advice? I have a Haltech E11v2 that i will be installing in my car soon, should i use the 3 bar map sensor that came with it, or go buy a z32 afm? I am aiming for 250rwkw+. Which one would be better for a stable tune, less likely to play up, and doesn't need to keep getting re-tuned.
From what I understand...
A Map sensor will need to be retuned everytime you do something different to the car from what I understand but wont stuff up,
Where as a afm will sort of 'adapt' to minor mods but can stuff up.
haltech ecu's are pretty damn hardcore. they shit over powerfc's, unfortunately theyre usually 3 times the price most of the time
map sensor wont be as affected by resin coming off a reusable air filter. my maf sensors have cooked a couple times after getting the medium cleaned after getting some of the oil on the sensor and then the sensor heats up and stops reporting the right flow. they can be cleaned, but i'd be going for the map sensor (I think thats what the powerfc D-jetro's are too, someone correct me if Im wrong)
-D
Damo/Allllllll of SAU, longtime no talk :D .
I have a crapload of high res skyline pics from various shows and many of jacks 33, and just heaps of skyline photos in general. What sort of pics are ya after? :D
Bosch 044 flow's 30% more then GTR iirc?
probably a better option depending on what power you want
true but a nismo fuel pump which flows just as well as the 044 can be mounted in the stock cradle without mods
the 044 is around $280 or so and the nismo is $450 odd, but if you're like me and have to pay for labour then its almost worth springing for the nismo
the 044 is an external fuel pump, im not sure how well they go with being submerged but i know people have done it
the 040 is internal but doesnt flow anywhere as near as much - its a good replacement for the oem pump but if ur running heaps of boost or aftermarket injectors you'd probably be best off just getting nismo - i plan to get nismo when it comes time to replace it. so far my stocker is still going nice
-D
-D
Ive got a GTR fuel pump in my car which was flowing 223rwkw but was leaning out which i think was due to injectors restricting flow but the stock GTR pump is fairly good :D
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
