anyone have some decent res pictures of skylines from car shows or private photo shoots that they dont mind me using for promotional material? Can you link to me your photo hosting site or email them to me?
Can anyone give me some advice? I have a Haltech E11v2 that i will be installing in my car soon, should i use the 3 bar map sensor that came with it, or go buy a z32 afm? I am aiming for 250rwkw+. Which one would be better for a stable tune, less likely to play up, and doesn't need to keep getting re-tuned.
From what I understand...
A Map sensor will need to be retuned everytime you do something different to the car from what I understand but wont stuff up,
Where as a afm will sort of 'adapt' to minor mods but can stuff up.
haltech ecu's are pretty damn hardcore. they shit over powerfc's, unfortunately theyre usually 3 times the price most of the time
map sensor wont be as affected by resin coming off a reusable air filter. my maf sensors have cooked a couple times after getting the medium cleaned after getting some of the oil on the sensor and then the sensor heats up and stops reporting the right flow. they can be cleaned, but i'd be going for the map sensor (I think thats what the powerfc D-jetro's are too, someone correct me if Im wrong)
-D
Damo/Allllllll of SAU, longtime no talk :D .
I have a crapload of high res skyline pics from various shows and many of jacks 33, and just heaps of skyline photos in general. What sort of pics are ya after? :D
Bosch 044 flow's 30% more then GTR iirc?
probably a better option depending on what power you want
true but a nismo fuel pump which flows just as well as the 044 can be mounted in the stock cradle without mods
the 044 is around $280 or so and the nismo is $450 odd, but if you're like me and have to pay for labour then its almost worth springing for the nismo
the 044 is an external fuel pump, im not sure how well they go with being submerged but i know people have done it
the 040 is internal but doesnt flow anywhere as near as much - its a good replacement for the oem pump but if ur running heaps of boost or aftermarket injectors you'd probably be best off just getting nismo - i plan to get nismo when it comes time to replace it. so far my stocker is still going nice
-D
-D
Ive got a GTR fuel pump in my car which was flowing 223rwkw but was leaning out which i think was due to injectors restricting flow but the stock GTR pump is fairly good :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
