That is a pretty looking turbo there Dave :)
So, what do you guys think of the wheels for my new bus? All you need to know is that she will be black, and a bit lowered :P
The wheels are the best offset I can go - unfortunately the offset of the standard wheels on the car are shameful, and even these wheels are a lot less dish than I want, but I cannot have wheels hanging out of my guards for a daily driver that deals with poholes and storm drains all day every day. I also don't want the cop attention. As it is they will be 34mm closer to the guards than the stock wheels, which will sit them nice and flush. (I have blacked out the centre caps, as I will be fitting them without them and I think they detract from the look of the wheel).
CE28N 18x8.5 +30 are the magic numbers .... and will be (slightly) stretching some 225/45 18s over them.
What do you all think?
lookin good andrew. id go another inch wider in the ass, but thats me.
:edit: i will murder the first every person who points out how wrong that is.
Edited by scandyflick
got my license back
BUT
1 Demerit Point for 2 and a half years , THEN i can get my P2's
:P
Welcome to granpa town bud. get used to looking down at ur spedo ever 3 secconds to make sure ur not speeding. i too got the same shit handed down to me. however it was before all this P1 P2 crap so once i my 2.5 years are over i go to my fulls finally.should have been on them over a year ago.i get my fulls start of next year :)
Will suit the new car nicely, definite win!
Glad you guys approve of my new wheels :) ..... I have been doing a shit-ton of research on what will and won't fit .... I am still going to borrow some of the same offset wheels of someone to try on the new beast before I sink my hard earned into the set pictured .... there is not too much information floating around on my new car .... few in the country and almost no-one modifying my specific model yet ....
Sorry Abe - hadn't really caught the goss about your turbo (*I only read bits and pieces of the Wasteland as time allows).
Looks good mate - but I fear the 0.8+ rear will be quite laggy .... if you are ok that with that, then go for it. If I was you I'd go have a long read about different turbo setups people have used in the forced induction section (which you may have already done). For a daily driver it may be a bit big methinks - unless you are going to whack it on a big ass top mount manifold, and always run a ton of boost through it. Trouble is you just can't drive a car with that much power on the street anyhow unless it is 4wd and/or has traction control - that thin glooks like it was built ro run over 300rwkw every day of the week.
But hey, each to their own. If you are happy, then that is all that matters.
For me, I am more than happy to have the awesome boost reponse my GT25/30 has, at the expense of 50rwkw that a bigger turbo would bring.
Got off the phone to hypergear and he said that would be enough to go about 320rwkw or so....for something like 260-280 he recommended a AT28G2 or something similar to a GT2871R for response and good hard hitting power
Response even from a 0.83 will be laggy as f**k considering the stock ones are 0.48 or something
a garrett gt3076 turbo will NOT make 320 rwkw!!!!!!!!!!!!
the bigger gt3040 with .82 rear exhaust housing will only just make above 300rwkw and thats on a forged engine and thas with external gate
Edited by ovrtym33
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
