Thought you might likeeeeeeeeeeeee
Also picking up some suspension for it while we are in Melbourne (all organised).
And still deciding on exhaust (and how far to go with it - or not), and wheels.
niiiice.
2.5" s/steel off the back of the engine, twin cats, jun x-pipe, cherry bomb glass pack mufflers, and then for the finale, 2 3" polished s/steel tips per side.
unless yours has the exhaust on one side only?
vq's sound f**king brilliant with a nice set of pipes, and youll have enough sound deadening to run em reasonably straight without suffering.
Edited by scandyflick
something different..maybe if u get them in say an 18 or 19", grr NO twink! i got lukey with an awesome wet willy tonight because of it!
Only saying those Torque Thruster rims, because i had them on my GTR in NFS prostreet and they looks awesome..win!
sorry twink, but muscle wheels do not belong on j cars. just looks whack as f**k...
... like twink.
Those parts are sex Andrew, kinda give away the car though :)
haha, i dunno, i can think of half a dozen other cars without trying.
... like twink.
Hate you.. :)
P.s Who is that chick in your pic?
could prove the most amazing outcome ever, tastes like iced coffee, but hot!
This is coming from a non FUIC drinker mind you, so im happy to risk it :D
Ill let you do the experiment then, I <3 my iced coffee to much to ruin it I think.
Have you tried that new vegimite??
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
