Thought you might likeeeeeeeeeeeee
Also picking up some suspension for it while we are in Melbourne (all organised).
And still deciding on exhaust (and how far to go with it - or not), and wheels.
niiiice.
2.5" s/steel off the back of the engine, twin cats, jun x-pipe, cherry bomb glass pack mufflers, and then for the finale, 2 3" polished s/steel tips per side.
unless yours has the exhaust on one side only?
vq's sound f**king brilliant with a nice set of pipes, and youll have enough sound deadening to run em reasonably straight without suffering.
Edited by scandyflick
something different..maybe if u get them in say an 18 or 19", grr NO twink! i got lukey with an awesome wet willy tonight because of it!
Only saying those Torque Thruster rims, because i had them on my GTR in NFS prostreet and they looks awesome..win!
sorry twink, but muscle wheels do not belong on j cars. just looks whack as f**k...
... like twink.
Those parts are sex Andrew, kinda give away the car though :)
haha, i dunno, i can think of half a dozen other cars without trying.
... like twink.
Hate you.. :)
P.s Who is that chick in your pic?
could prove the most amazing outcome ever, tastes like iced coffee, but hot!
This is coming from a non FUIC drinker mind you, so im happy to risk it :D
Ill let you do the experiment then, I <3 my iced coffee to much to ruin it I think.
Have you tried that new vegimite??
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
