Andrew, glad you enjoyed the tickets mate, definately a good game to be at and a great result for the good guys! Don't thank my mum (she's one of those retard feral supporters), the tickets belong to the missus' parents, I'll pass on your thanks
LOL Luke, them's fighting words!! :thanks:
Your Mum sounds lovely and should disown her ghey son! :thumbsup:
Hope she has a full recovery, she sounds like a classy lady. :)
I will chuck them on a DVD and drop them to you tomorrow or Wednesday Guy (along with your fishing tackle box you left in my car from the Balgowan fishing trip). And I will take Di up on her kind Schutzenfest delivery offer too :)
Nope haven't read the books. Don't have time to read these days either :(
And Pete - you will be glad to know that my brother-in-law David (who is coming on the weekend trip) is also a feral Port suppporter .... so it will be 2 on 1 :( I actually took him to the match yesterday, and he was bizarrely quiet all match :) .... quite the opposite to the earfuls I got earlier in the year when you guys did us ;)
Hey Pete, how are those gates coming along?
Fantastic thanks young Chadwick!!
Thanks for the awesome weld job....I'll put some pics up of them at some stage.
I sent you a text today....still waiting for a reply dude.
EDIT: Andrew, I think Dave and I will be very quiet after yesterday's effort, LOL.
And Pete - you will be glad to know that my brother-in-law David (who is coming on the weekend trip) is also a feral Port suppporter .... so it will be 2 on 1 :( I actually took him to the match yesterday, and he was bizarrely quiet all match :) .... quite the opposite to the earfuls I got earlier in the year when you guys did us :(
Funny that ;)
looks like ill be taking my dump pipe down to andrew to be modded to fit the somewhat larger turbine...
... and get a screamer. ;)
good to hear man. :(
Your dump won't need to be modded. And screamers on internal gates aren't a great idea either.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
