The answer to all your questions there are, no idea :(
I will be pulling it out when i put the new turbo, and ecu in...so 1-2 months time. As for cost, no idea how much they go for, plus i may hang on to it for regency issues. Power wise...Krishy i think is still using a stock series 1 afm, so about 220rwkw, maybe a bit more.
very very nice power figure Dave specially when its untuned.....R33 AFM's are good for about 250rwkw's and that would be most likely maxing them out at that point....i am going to get the car tuned with the stock AFM and see how much we can squeeze out of it before swaping to a Z32....i am only making 211 atm.....Saturday should tell :(
can someone help me out ?
i bought an engine off this forum which was apparently working etc etc and had been pulled apart and put back together professionally but after putting it in the car and
being compression tested it has low compression (waiting on exact figures).
the guy i got it off said that when i picked it up it had a timing belt on it and the timing was set to tdc but ive come to find that it was missing idler and tensioner pulleys , not to mention
it was also missing oil seals around the back of the cam pulleys and its missing bolts off the intake manifold.
it also had heaps of missing coolant lines...
what can i do ?
ask for my money back ?
ask him to pay for repairs ?
shit mitch your situation is getting worse day by day mate.....well you can give the seller the 2 options and see what he says in regards to it....goodluck with it mate....just cant wait to see your ride back on the road
you and me both man !
so over this crap
but i got some good news this morning
got accepted into tafe to study Cert II in Automotive Mechanical , starting jan next year :)
makes me think about my power figures....when i first got my car tuned..it still had its n/a fuel pump and reg...but had a early darkhalf rechipped ecu (before realtime) and rb20 redtop nics injectors...it pulled 175.4kw at the treads..but leaning out big time in the top end....this latest tune it had a bosch 040 pump and a vlt reg...but only pulled 150.....my first tune it was still using the same AFM as when the car was on lpg n/a and had it blown apart a few times.....i dont get it....when it was first tuned....it had the same fuel filter and plugs from over a year previously....me dont know...me too little
Dave, get in touch with luke
he still has his GTR pump, and glenn has a Z32 that he'll no longer need, solves both problems then
Correct, got a nice GTR fuel pump sitting here with your name on it. And Glenda has a Z32, problem solvered
messing around with the valve timing without knowing what you're doing can definitely have an effect on compression.......very easy to dial in and dial out compression by varying the valve timing slightly.
Might be running like crap though but if it's not running yet, be careful of any valve to piston contact
what can i do ?
you can ask for anything but your chances of getting it are minimal since it was a private sale so it's a case of buyer beware. that's why buying engine off wreckers will cost you more because they generally come with a start up warranty, so in this case you would have been covered.
I'm still waiting for you to clear the air about your claims about TT. you read the post that SLED made and yet you didn;t see fit to reply.
SCANDY;
S1 R33 and R32 AFM will support around the 210-220rwkw, but the SII R33 (pink sticker, 3 wire plug) will support around the 235rwkw mark. i wouldn't pay more than $100 with the plug for one. I paid $55+20 for the plug for mine and if you look around you can still find them for that price.
Edited by D_Stirls
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
nice. how much? :)
SCANDY;
awesome. cheers dale. ill see what i can find.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
