The answer to all your questions there are, no idea :(
I will be pulling it out when i put the new turbo, and ecu in...so 1-2 months time. As for cost, no idea how much they go for, plus i may hang on to it for regency issues. Power wise...Krishy i think is still using a stock series 1 afm, so about 220rwkw, maybe a bit more.
very very nice power figure Dave specially when its untuned.....R33 AFM's are good for about 250rwkw's and that would be most likely maxing them out at that point....i am going to get the car tuned with the stock AFM and see how much we can squeeze out of it before swaping to a Z32....i am only making 211 atm.....Saturday should tell :(
can someone help me out ?
i bought an engine off this forum which was apparently working etc etc and had been pulled apart and put back together professionally but after putting it in the car and
being compression tested it has low compression (waiting on exact figures).
the guy i got it off said that when i picked it up it had a timing belt on it and the timing was set to tdc but ive come to find that it was missing idler and tensioner pulleys , not to mention
it was also missing oil seals around the back of the cam pulleys and its missing bolts off the intake manifold.
it also had heaps of missing coolant lines...
what can i do ?
ask for my money back ?
ask him to pay for repairs ?
shit mitch your situation is getting worse day by day mate.....well you can give the seller the 2 options and see what he says in regards to it....goodluck with it mate....just cant wait to see your ride back on the road
you and me both man !
so over this crap
but i got some good news this morning
got accepted into tafe to study Cert II in Automotive Mechanical , starting jan next year :)
makes me think about my power figures....when i first got my car tuned..it still had its n/a fuel pump and reg...but had a early darkhalf rechipped ecu (before realtime) and rb20 redtop nics injectors...it pulled 175.4kw at the treads..but leaning out big time in the top end....this latest tune it had a bosch 040 pump and a vlt reg...but only pulled 150.....my first tune it was still using the same AFM as when the car was on lpg n/a and had it blown apart a few times.....i dont get it....when it was first tuned....it had the same fuel filter and plugs from over a year previously....me dont know...me too little
Dave, get in touch with luke
he still has his GTR pump, and glenn has a Z32 that he'll no longer need, solves both problems then
Correct, got a nice GTR fuel pump sitting here with your name on it. And Glenda has a Z32, problem solvered
messing around with the valve timing without knowing what you're doing can definitely have an effect on compression.......very easy to dial in and dial out compression by varying the valve timing slightly.
Might be running like crap though but if it's not running yet, be careful of any valve to piston contact
what can i do ?
you can ask for anything but your chances of getting it are minimal since it was a private sale so it's a case of buyer beware. that's why buying engine off wreckers will cost you more because they generally come with a start up warranty, so in this case you would have been covered.
I'm still waiting for you to clear the air about your claims about TT. you read the post that SLED made and yet you didn;t see fit to reply.
SCANDY;
S1 R33 and R32 AFM will support around the 210-220rwkw, but the SII R33 (pink sticker, 3 wire plug) will support around the 235rwkw mark. i wouldn't pay more than $100 with the plug for one. I paid $55+20 for the plug for mine and if you look around you can still find them for that price.
Edited by D_Stirls
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
nice. how much? :)
SCANDY;
awesome. cheers dale. ill see what i can find.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
