The answer to all your questions there are, no idea :(
I will be pulling it out when i put the new turbo, and ecu in...so 1-2 months time. As for cost, no idea how much they go for, plus i may hang on to it for regency issues. Power wise...Krishy i think is still using a stock series 1 afm, so about 220rwkw, maybe a bit more.
very very nice power figure Dave specially when its untuned.....R33 AFM's are good for about 250rwkw's and that would be most likely maxing them out at that point....i am going to get the car tuned with the stock AFM and see how much we can squeeze out of it before swaping to a Z32....i am only making 211 atm.....Saturday should tell :(
can someone help me out ?
i bought an engine off this forum which was apparently working etc etc and had been pulled apart and put back together professionally but after putting it in the car and
being compression tested it has low compression (waiting on exact figures).
the guy i got it off said that when i picked it up it had a timing belt on it and the timing was set to tdc but ive come to find that it was missing idler and tensioner pulleys , not to mention
it was also missing oil seals around the back of the cam pulleys and its missing bolts off the intake manifold.
it also had heaps of missing coolant lines...
what can i do ?
ask for my money back ?
ask him to pay for repairs ?
shit mitch your situation is getting worse day by day mate.....well you can give the seller the 2 options and see what he says in regards to it....goodluck with it mate....just cant wait to see your ride back on the road
you and me both man !
so over this crap
but i got some good news this morning
got accepted into tafe to study Cert II in Automotive Mechanical , starting jan next year :)
makes me think about my power figures....when i first got my car tuned..it still had its n/a fuel pump and reg...but had a early darkhalf rechipped ecu (before realtime) and rb20 redtop nics injectors...it pulled 175.4kw at the treads..but leaning out big time in the top end....this latest tune it had a bosch 040 pump and a vlt reg...but only pulled 150.....my first tune it was still using the same AFM as when the car was on lpg n/a and had it blown apart a few times.....i dont get it....when it was first tuned....it had the same fuel filter and plugs from over a year previously....me dont know...me too little
Dave, get in touch with luke
he still has his GTR pump, and glenn has a Z32 that he'll no longer need, solves both problems then
Correct, got a nice GTR fuel pump sitting here with your name on it. And Glenda has a Z32, problem solvered
messing around with the valve timing without knowing what you're doing can definitely have an effect on compression.......very easy to dial in and dial out compression by varying the valve timing slightly.
Might be running like crap though but if it's not running yet, be careful of any valve to piston contact
what can i do ?
you can ask for anything but your chances of getting it are minimal since it was a private sale so it's a case of buyer beware. that's why buying engine off wreckers will cost you more because they generally come with a start up warranty, so in this case you would have been covered.
I'm still waiting for you to clear the air about your claims about TT. you read the post that SLED made and yet you didn;t see fit to reply.
SCANDY;
S1 R33 and R32 AFM will support around the 210-220rwkw, but the SII R33 (pink sticker, 3 wire plug) will support around the 235rwkw mark. i wouldn't pay more than $100 with the plug for one. I paid $55+20 for the plug for mine and if you look around you can still find them for that price.
Edited by D_Stirls
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
nice. how much? :)
SCANDY;
awesome. cheers dale. ill see what i can find.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
