Just got home from David Copperfield and damm, He has some skills. Making 8 ppl disappear off stage. Making a car in mid air on stage appear. So much crazy shit.
Was worth the money seeing him.
He's a pole smoker so he will reply.
He races a shitty little tin top standard class car and he loves telling people what the rules are in Dirt Circuit when he has only been racing for 2 years. People like my brother and me have around racing all our lives; dad raced before we were born, and we have been racing ourselves since we were 10. Yet he loves informing us of the rules. He's a pole smoker!
Well i'm pulling the engine out tomorrow to clean some stuff up for Extreme HP Show, so if i have the engine back in i'll make an appearance. I'll be fitting the 264x9.0 cams while the engine is out so it'll be making some more power when it runs next. Hopefully 230-240rwkw @ ~17psi, but at that point the AFM will be at it's limit.
Edited by D_Stirls
more than a little keen to buy this...
... wouldnt mind getting my fat ass back to street riding :P
I bought this back: :)
and this:
= WIN!
I might also throw some SAU:SA stickers onto it
:D
^^Nice looking bike Ruby ;)
Unfortunately, my mate who bought it off me (and I'm subsequently buying it back off) resprayed it a yellow, red, green theme :D and I'm going to respray it back to its original colours (as in the pic). I gotta source the decals from the UK again ... but thats okay, because the Tyga race system is coming from the UK also. I've got until Feb next year to set this bike up ready for next season. Might sound like enough time, but I'll be working interstate 3 weekends over 3 months and due to missing some local practice days at Mallala, that only leaves me 1 (maybe 2) track sessions for myself to test and tune it.
Check this out:
Yes, thats a runway which goes right thru a major city highway. They shut the highway down everytime a plane needs the runway :thumbsup:
or you can buy my 31 :thumbsup:
I sorta have a cheap R31 already..468,000 k on it
purrs like a kitten still
just think a car like daves old one would be good, there cheap as hell now, less then 9k for a cool one
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
