well it isnt sunny up here today thats for sure, yesterday was awesome tho nice warm sunny weather! why did today have to be dark and gloomy!!!!
i really dont want to go outside today :( would rather stay inside and bake stuff :blush:
Right you lot ...
I'm off to Ballarat today for a bit of R&R for the next 4 days.
To all those who've given me their membership forms for SAU:SA, I processed them and organised your membership cards, and am just confirming your transfer with the bank. Your membership cards will be received by mail and I've given Ash a list of new members for the SA members forum. I'll chase up the status of all this and finish off the rest when I get back from my holidays on Monday.
:blush:
I just had drinks for lunch at the tailem bend pub for lunch I was told that darren leahman the cricketer will be shouting drinks on saturday from 12 to 1pm
haha, if he is still sponsored by XXXX, he will just be handing out that Queensland cat piss :yes: He did it when we played cricket at the same club, would rock up with 3 free cartons, too bod no one likes the stuff!
that last pic is awesome.
and woo! got my acre brake pads today, so i can finally fit my front rotors, gonna be a busy weekend, alignment, engine mounts, brakes, and tracing a leak. fun fun fun.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
