now that is some funny shit hahaah
Yep, having watched the normal AND the Unrated versions of Sex Drive - top movie in both forms! The beauty of the unrated one is the random naked chicks running through the set for no apparent reason every so often .... classic.
what happens if you plug up both breather on an engine ;) what can break/fail/die?
what happens??? a small somalian child dies...thats what happens.......
actually...its not good to block both breathers...thats why they are called breathers....its part of the crank case ventilation system..you block them off and the vapours caused by the cavitating oil in your sump will try and find the easiest way out...which means your timing cover and rear main oil seals will be the first things to leak....
actuall it surprises me how coherent i am this time of the morning without my coffee :D
Is it just me who is getting no reponse (not loading, page cannot be displayed etc.) from the SAU website sometimes in the last week? like 2-3 minutes ago?
I get it all the time. I'm sure the gurus are working on it.
every now and again it takes AGES to load, but only stalls for about 2 mins and is then back up.
Okay cool, so its not me then. Ive been having a few dropouts lately which I never had before, but its obviously un-related and also I cannot access anything when it does it.
Okay Im off to bed, last nightshift tonight... THHHHHAAANNNNNK GODDDDDDDDD
anyone else a big fan of dexter? love it! got S1 and S2 at home, almost finished season 1.
awesome show, i finished season 3 earlier this year
season 2 was the best imo, the ending is brilliant!
the show's addictive - if you start watching it a few episodes into a season (on TV) [edit - i reccommended it to friends of mine and they couldnt get into it], you wont be interested. gotta watch it from the start!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
