ill see how it pans out. not a huge fan of the s15's looks (14a is miles tougher imo) but the interior is a shit load nicer than the 14...
this confirms ur queer, s15 looks way better im sure most will agree. specially the tail lights.
far out, booking a holiday to Bali, adjusted the dates slightly and the times of departure and it dropped the final price by $300 each! :thumbsup:
I think last time I went it was like 699.00 RT on Guaruda airlines and 8 days in a decent hotel on the beach in Kuta.. the place is awesome and the people are so nice.
spend the extra on upgrades if you fly them, you will fill your luggage up and the upgrade to biz class or what they call it is well worth it. 150 bucks I think each
gives you extra weight in luggage to bring back crap galore..lol
this hotel, 4 stars too
Bugger was hoping a bit more wider and stupider offset. lol
Come on tell us. I'll send more pics of truck LOL
lol, i always thought +5 was pretty silly. hear 35mm boltons are pretty cheap these days. :thumbsup:
JIS get a new container in Dave? :D
Actually they do Damo :(
yup. went and saw them today. deals may or may not have been done.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
