"Premium100 is a high performance petrol with an octane of 100, which is the highest rating available in the Australian market. Ethanol is a natural octane enhancer - adding 10% ethanol to petrol boosts its octane number and its performance. Ethanol helps the other components in petrol burn more completely. It also has a cleaning effect on the cars fuel system. Premium100 will give your car more zip! "
reading from that it should b better then BP ultimate. i might have to give it a try... i fill up tuesdays so might use it 2moro. any1 tried it?
Just be careful with ethanol blend fuels! I put some 98/10% ethanol in mine and the knock reading skyrocketed. Was tuned on Ultimate 98, tuner said that any ethanol blend fuel is trouble unless you retune for it. Due to the amount of extra fuel needed and less timing because of higher burn rate. My knock went from 30 on ultimate to over 200 on ethanol blend!
Oh and Damo, go for the chrome/orange globes. Last thing you want is nice clear side markers with daggy orange globes.
I am speaking to Luke_ENR about it, which seems to be clearing it up a bit for me.
I get the 040 in the cradle, but it doesn't go back into the tank. I now have a theory that the end/base of the 040, needs to be in the same position as the OEM pump. I was mounting the 040 a little bit further down, where the "C" bit of the cradle is, was where is was putting the line on the 040. the "C" bit, holds the OEM to the cradle as it has the pickup go through it.
ffs I couldn't have imagined it being so frustrating trying to buy a "near new" car .... I think I am on a winner this time - we will see what the mechanical check picks up on THIS one tomorrow.
pritty sure there is a guide on the site??
also i thought that the 040 is not a direct fit replacment?? but maybe thats just for gtr's
It isnt, you need to modify the cradle...but i think i know what to do now. I did look at the guide, it helped me a bit.
lol. turned into quite the mission for you. fingers crossed this one pans out. sedan or coupe?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
