yeah at the end of the day, the club is a means to get a bunch of mates who share a general & common interest, whether it be a track day, car show, dyno day or just dinner & drinks it doesn't really matter.......it hopefully keeps the rev-heads off the streets and alive a little bit longer. :)
fishy, if you're actually serious, then that is the most ill thought statement you've ever made.
With that kinda a logic, what's the point of anyone having any car club then?!
I really don't understand so called motor enthusiasts that just want to be constant knockers towards anything new trying to get off the ground........not that car clubs in general are anything new.
I really hope you were only saying that "tongue in cheek" fishy cause you're better than that.
if you really want to discuss my personal decision on why i haven't joined SAU:SA yet, i'll happily discuss it with you via PM or face to face/phone (i had written more than this, but figured this is the best way to go about things)
oh, and i was reminding vu that some of us may not have seen his sugestion... =\
edit: probably should just enphasise the word YET (used in both posts)
Edited by Fishpaste~
if i wasnt saving my ass off pete i most likely would of. im even fixing the silvia up to put it up for sale for some more cash :):P
hope you all have fun without me though...*runs to the corner and cries*
Edited by Import S13
To do list is:
Heres my list...
My list for Loxton.
1. Fit N1 vent inserts
2. Re-leather steering wheel
3. Fix the intermittent 2000rpm idle
4. Fit Coilovers
5. Fit my Gramlights
6. Replace air conditioner compressor
7. Fit new front speakers
Probably something Ive forgotten haha.
When you get your steering wheel done, post pics and let me know how much,
Wouldnt mind getting my Nardi rebound in fresh plush new leather :P
I will get Wiltshire Motor Trimmers to do it, cost is ~220 last I knew. but I will take pics and let you know :)
My list for Loxton.
1. Fit N1 vent inserts - easy.
2. Re-leather steering wheel - dont be a pussy, buy a nardi.
3. Fix the intermittent 2000rpm idle - workshops are awesome for shit like this.
4. Fit Coilovers - easy.
5. Fit my Gramlights - easier. could get my sister to do it for you if youre not sure. lol.
6. Replace air conditioner compressor - got a spare weekend?
7. Fit new front speakers - piss easy.
Probably something Ive forgotten haha. - smash a carton
Edited by scandyflick
does anyone know if there is any decent cars for sale, thats under or around 15k?
There are lots Kye. What, specifically, did you have in mind?
Look hard enough and you can find a 32 GTR in need of some TLC.
I know of a 4 door 33 for sale :)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
