yeh thats what im thinking matty..
also, just picked up my rolla from workshop to have a $710 bill..
what was done?
diff locked, vlturbo pump supplied by workshop)(its external so 5min job), indicator switch ($30), oil filter ($15), tighten back brakes (handbrake still doesnt lock), compression test..
7.5hrs labour to do that?? $500 just for labor? is this correct or should i not go there again?
If it was 7.5 hrs then $500 is a good price. I pay around the $85+gst mark per hour
I have nfi about mechanics so I dont know about the time, but given the list of stuff u got done, it wouldnt surprise me if that were about right
-D
i was gonna say, whats coming next :)
It'll be another 180 to do that 25 conversion on. with all the parts that would be coming out to do the conversion i would be basically parting out the whole car so I'll sell the current 180 and start again with another stocker.
for anyone thats keen, a few of us are going to the Lakes hotel to watch the game tonight.
141 Brebner Drv
West Lakes SA 5021
if you need my number for anything, shoot me a pm. Myself and Adrian will be there at around 6ish, game starts at 6:30
xoxo
Should be a mint game, Carn the Crows :)
Got my coilovers in, fully wound down it sits lower, but not as low as I would like but ohwell,
I got something coming that will be my fitment pig :) aha
Edited by Weezy
shouldve got a set that are base height adjustable. run as low as you want without having a crazy uncaptive spring.
but yeah, run it a little high, bout the height of heslo's car would be ideal, low cars sucks.
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
