shouldve got a set that are base height adjustable. run as low as you want without having a crazy uncaptive spring.
but yeah, run it a little high, bout the height of heslo's car would be ideal, low cars sucks.
Truth! Looks the goods, handles well and you're not dragging your ass around everywhere
yeah that's why i love my progressive spring rate
can anyone tell me how much power i might be able to gain with a set of cams (not shafts etc. just the gears) on a rb26? tuned once their on of course.
just trying to see if its even worth getting them.
Edited by Import S13
Rental property got broken into over night I just found out, they basically stole everything and I mean everything from dishwashers to toilet bowls, door bells, kitchan taps, cleaning fluids. Pretty crazy. Cops know who done it tho.
Trading post ad FOR sale ,, slightly used crapper....lol
that sucks luke , what is this world coming too...
Power gain would be minimal, but the cam gears will help bring the power forwards in the rev range.
Just changed my fuel filter and damm, the fuel that came out of it was black as lol. All better now with a new one on and minimal fuel lost.
Pliers make alright fuel line clamps with cable ties around the end lol.
too legit to quit!
cable ties in general are best.
i used them as head studs , worked a treat
So who's good with computers? My home comp won't load anything. You turn the harddrive on but it just looks like it not doing anything, only thing moving is the fan :bunny: . The light on the screen just keeps flashing so it looks like it's not loading the hard drive arr help plz
With big turbos cams can make you up to 50kw depending on the size of the turbo and the amount of head work done as they allow you to move the turbos into their efficiency range, but like chad said with small turbos they won't affect peak power much but will allow you to move the power around the rev range and can get you some nice gains on torque.
Here's some graphs from when we were playing with the cam gears on my car.
ripped smashed deATH. DRNK
:bunny::)
So who's good with computers? My home comp won't load anything. You turn the harddrive on but it just looks like it not doing anything, only thing moving is the fan :P . The light on the screen just keeps flashing so it looks like it's not loading the hard drive arr help plz
First, does it make any beeps when you turn it on? If it does, what's the sequence? This can determine if it's a dead video card, RAM, CPU, etc.
Second, can you try another monitor? Have you tried unplugging it from the video card and plugging it back in?
If it was a dead hard drive, the PC would at least still turn on to display the BIOS, etc.
I think what Luke is referring to as the 'hard drive' is the actual case/box, as many noob PC people do.
Take it to someone who knows what a 'hard drive' actually is Luke - mehinks you are not about to figure this one out yourself :bunny:
Bring it to me mate, ill sort it out for ya for free...other then parts cost if it needs any.
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
