Saw a guy filling up a blue 33 GTST this morning with 91 octane and when i aked him what he was doing he goes i put octane booster in.
does he not realise that 91 is the best that fuel will ever be and if it has been sitting it is probably more like 88 or 89!!!!
Do not know what octane booster he is using but as far as i know they can only lift the octane rating up to 5 points which would still put him in the range of a blown motor!!!
Plus i have found that octane booster tends to foul the plugs ig not used out on the track or on a hill run.
just my observations
Had an interesting morning so far.
Got pulled over by the po-po in front of Prince Alfred College earlier - random bretho, cop was a nice chap who asked if I get pulled over much and explained that the criminals that steal the cars are more to blame for pullovers than anything, which is understandable. Took all of 5 minutes and they let me go, was not a drama at all - they didnt even ask to see my licence...
then im driving down port rush road and this ranga mofo that looks like jacko jackson sticks his head out of the passenger window of the magna he was travelling in, and yells at me "I f**kEN HATE BUSINESS C***S"
OK so I'm in a skyline and I have a collared shirt. Shoot me. Would've love to have NOT been caught in traffic, would have loved to have said something about him being an inbred bogan ranga mofo, but for all I know he was a methhead who wanted to punch on. Ahhh fun times. I just wish I was allowed to pack a gun and execute these vermin as I see fit (kind of like Judge Dredd but in a GTR instead of a bike)..
-D
For those interested in seeing what the Work Emotion 11Rs look like, I sold them and bought a set of gold Advan RG2s in GTR offsets for my Evo 8. End result should be something like this, in silver, minus the stickers...
its a permacool block adaptor and an earls relo block. 3/4 -16 thread or something on both. too small. gave em a call, theyll sort it out tomorrow, their little book said it would fit, so theyll just swap over to the stuff i need.
the filter thread on your car is M20x1.5, it's the non VTC SR20's that are 3/4x16. I would keep the 3/4 thread in the filter block and change the one that bolts to the engine as there is more filter availability in the 3/4 thread.
Better yet go to Racespec and get one of these;
http://racespec.com.au/product_info.php?cP...products_id=498
Edited by D_Stirls
awesome. shall keep that in mind. thanks dale.
and wouldnt it be a gi-f**kin-gantic pain in the ass to fit that adaptor?
Edited by scandyflick
Well hopefully i've now fixed my coolant leak (dodgey genuine water pump), and my reversion problem caused by my hard intake pipe. Be the first time i've driven it in about 3 weeks!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
