its even better when you get the best table in the house, and can just walk past the line up next door and straight into a reserved booth next door.
Why do I get the feeling I'm not missing anything by staying away..... Hmm
[rant] 2 x LH + 2 x RH headlight globes shit themselves in 10 months I've had the car :down::mad::) [/rant]
lol Cara, need a females opinion here.
Gauchos for Argentinian dinner, then Escobar for drinks, dancing. Does that sound good for a first date with this girl?
lol. both brilliant joints, mad popular, line up on a saturday night is 50-100 people.
i just got the mad hookups.
dude.
its win. trust. youll be throwing her dress on your floor in no time.
my 2 cents, warranted or not,
for the love of god stay away from ENIGMA.
hahaha went thru there last night for a sec. phone wasnt working. lost my friends after teh casino. . just walked around like a minda for most of the night. In the end just went to worlds end and drank myself stupid
i went there for a gig once. god damn it sucks. shit acoustics, shit bar, shit crowd.
your asking on a car forum for a females advice?? i think you have bigger problems
Everything is sticky and full of emo's. As long as your drunk or munted it doesn't matter where you get out too...?? Sounds like a good night...
emo girlies arent that bad for one nighters. shotz on a saturday night is full of hot emo gangies.
I'll keep that in mind. You're not talking from experience?
Long live the red army, if it wasn't for stalin, as harsh as i was, they would of lost WWII, or is that too far off topic?
off topic but stalin didnt win ww2. the russian peasants did. and then he went and executed 8 million of them
stalin killed more than hitler - i cant say I share your sentiments
-D
50% Polish
100% Strapped
experience is good, am glad you decided to share. shotz is a good plan B. it is pretty cheap. the last time i went there i couldn't remember getting home.
Dohmar, i haven't read about russia yet, halfway through my hitler book and just finished reading about operation "barbarossa" and now starting the chapter "fullfilling the prophecy".
Did he defeat the reich and then take his power too far, i know his semi evil but i guess i had no idea. Had to be some kind of leader to defeat the fuhrer and take back his conquered territory??
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
