The Sa Wasteland
Cubes
 Share
SCOUSERS JOIN FERRARI
"The Ferrari F1 team fired their entire pit crew yesterday."
This announcement followed Ferrari's decision to take advantage of the australian government's 'Work for your Dole' scheme and employ some lonsdale youngsters.
The decision to hire them was brought about by a recent documentary on how unemployed youths from lonsdale were able to remove a set of wheels in less than 6 seconds without proper equipment, whereas Ferrari's existing crew could only do it in 8 seconds with millions of pounds worth of high tech equipment.
It was thought to be an excellent, bold move by the Ferrari management team as most races are won and lost in the pits, giving Ferrari an advantage over every other team.
However, Ferrari got more than they bargained for! At the crew's first practice session, not only was the lonsdale pit crew able to change all four wheels in under 6 seconds but, within 12 seconds, they had re-sprayed, re-badged and sold the car to the Mclaren team for 8 cases of vb, a bag of weed and some photos of Lewis Hamilton's bird in the shower.
We should be so proud of our exports :)
Nope. the car went in to fix up the ratios from lean to normal, but im not sure what they are.
you should always ask for a print out of the air/fuel ratios which they can put on your dyno sheet graph and also ask how much timing its running
thats the mistake i made "not knowing my air/fuel ratios and timing" and 2 months later they leaned my car out on the dyno
bye bye piston 6 ring land after spending ALOT of $$ with them!!!!!!
Valiant update:
Drove it around the block today, and it over heated lol. Pulled the thermostat out and it was siezed up. The pipe was all blocked from corrosion. Cleaned all that out and got it looking nice. Changed the spark plugs and dropped the oil.
Tomorrow i will:
Fill up with coolant and put thermostat in.
Put new engine oil in
Hopefully find someone with a fuel filter instock
And give it a basic check over
Other then all that it will get a wash sometime before sunday.
hey guys...
anyone changed their brake pads (diy) before (specifically 4 piston calipers [33/34gtst])? got any tips for slotting those new pads into the caliper?
those pistons are tough to get past without special tools. Dont want to damage anything! Anyone got any tips?
Just seeing if there's a simple way to install. otherwise i'm going to put the old pads back in and hand it over to my mechanic!
looked at the DIYs but i'm sceptical about some of the methods, and want to avoid damaging anything at all costs
hey guys...
Luke HESLO is the man to speak to, did an awesome job fitting my pads n rotors
i could also add that pete (sled) and luke (lukeenr34) did an admirable job of fitting my front rotors and the 2nd hand pads they found that were infinately better than the ones I had ..
eternally greatful
-D
cheers guys. done a bit more digging in the meantime
gonna take another look. if i think i can compress them properly with the tools i have i'll give it a crack!
otherwise going to put it all back as mentioned
thanks again
what would be the cheapest way to get a car back from vic
drive my mums car and hire a trailer for a couple of days n do an overnight trip?
I had a car freighted over using movingcars.com.au - the actual carrier they used was Patrick Autocare and from memory it was $300 something from Melbourne. It must be able to be driven onto the truck though.
 Share
    • There isn't that many cars yet that are using electric coolant pumps, but they are slowly becoming more common, especially in the euro brands.  back in 2009, they were quite rare, pretty much all were either timing chain or accessory belt driven. That said, the VQ37VHR isn't an uncommon engine, so any decent mechanic should be able to replace the water pump.  I don't live in NSW, so can't make any suggestions.
    • I do not think that the return pipe could be the cause of your particular troubles, unless perchance it is leaking in a lot of unfiltered and unmetered air (assuming your ECU is still using AFMs). And then it could be very bad, but it shouldn't prevent you making boost. Blow then engine up from running lean? Sure. But it would make boost. You really needed to disconnect this thing from the turbo inlets and close those inlet ports off a year ago, and you should do it now.
    • Pressure Ratio = 2. ie, 1 bar of boost (assuming 1 bat absolute pressure at the compressor inlet). This is relevant because compressor maps do not have "boost" up the y-axis. They have pressure ratio.
    • Revisiting this thread again x2... 1 year later. This car has been an ongoing project between life. But, I never removed the re-circ pipe. I know, shame on me. But since then, i took it to get tuned and only making about 280hp (lame) and i'm chasing a boost issue where the car wont boost past 7-8psi. Mac valve installed. Haltech Platinum pro with the map sensor.  This is the first time i've tackled the turbo side of things, but i have that side somewhat taken apart to chase the waste gate vacuum lines. And noticed this stupid pipe again. I'm peicing together the puzzle and @GTSBoy mentioned that it was a big vaccuum chamber and said a bunch of car math stuff that I couldn't quite follow the car math (im trying). You guys think this would be the culprit? between rotting vacuum hoses?  i'm making a DIY boost leak tester this weekend.
