SCOUSERS JOIN FERRARI
"The Ferrari F1 team fired their entire pit crew yesterday."
This announcement followed Ferrari's decision to take advantage of the australian government's 'Work for your Dole' scheme and employ some lonsdale youngsters.
The decision to hire them was brought about by a recent documentary on how unemployed youths from lonsdale were able to remove a set of wheels in less than 6 seconds without proper equipment, whereas Ferrari's existing crew could only do it in 8 seconds with millions of pounds worth of high tech equipment.
It was thought to be an excellent, bold move by the Ferrari management team as most races are won and lost in the pits, giving Ferrari an advantage over every other team.
However, Ferrari got more than they bargained for! At the crew's first practice session, not only was the lonsdale pit crew able to change all four wheels in under 6 seconds but, within 12 seconds, they had re-sprayed, re-badged and sold the car to the Mclaren team for 8 cases of vb, a bag of weed and some photos of Lewis Hamilton's bird in the shower.
We should be so proud of our exports :)
Nope. the car went in to fix up the ratios from lean to normal, but im not sure what they are.
you should always ask for a print out of the air/fuel ratios which they can put on your dyno sheet graph and also ask how much timing its running
thats the mistake i made "not knowing my air/fuel ratios and timing" and 2 months later they leaned my car out on the dyno
bye bye piston 6 ring land after spending ALOT of $$ with them!!!!!!
Valiant update:
Drove it around the block today, and it over heated lol. Pulled the thermostat out and it was siezed up. The pipe was all blocked from corrosion. Cleaned all that out and got it looking nice. Changed the spark plugs and dropped the oil.
Tomorrow i will:
Fill up with coolant and put thermostat in.
Put new engine oil in
Hopefully find someone with a fuel filter instock
And give it a basic check over
Other then all that it will get a wash sometime before sunday.
hey guys...
anyone changed their brake pads (diy) before (specifically 4 piston calipers [33/34gtst])? got any tips for slotting those new pads into the caliper?
those pistons are tough to get past without special tools. Dont want to damage anything! Anyone got any tips?
Just seeing if there's a simple way to install. otherwise i'm going to put the old pads back in and hand it over to my mechanic!
looked at the DIYs but i'm sceptical about some of the methods, and want to avoid damaging anything at all costs
hey guys...
Luke HESLO is the man to speak to, did an awesome job fitting my pads n rotors
i could also add that pete (sled) and luke (lukeenr34) did an admirable job of fitting my front rotors and the 2nd hand pads they found that were infinately better than the ones I had ..
eternally greatful
-D
cheers guys. done a bit more digging in the meantime
gonna take another look. if i think i can compress them properly with the tools i have i'll give it a crack!
otherwise going to put it all back as mentioned
thanks again
what would be the cheapest way to get a car back from vic
drive my mums car and hire a trailer for a couple of days n do an overnight trip?
I had a car freighted over using movingcars.com.au - the actual carrier they used was Patrick Autocare and from memory it was $300 something from Melbourne. It must be able to be driven onto the truck though.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
