well, the unnamed speed shop still doesnt have my part in.
lol they promised you 3 spoon engines?
Johnny Tran: [interrogating Ted about his missing engines] What are feeling, Lance... 40 weight? 50 weight?
Lance Nguyen: 40 Weight sounds nice...
I thought they were NEESON SR20's?
needed help asap. Anyone know how to replace a castor rod in a 32?
Easiest job in the world if it is like the R34 (and a castor rod is the same as a Z bar).... 2 nuts from underneath near the wheel hub, and a double ended bolt/nut through the bush at the front and you are done. Just jack up the car, rip off the wheel and you will see how easy it is.
yep, its not too hard, and everything is easy to reach, which is a bonus :cool:
Dang, you must be pissed by now Dave .... but lesson learnt not to buy stuff for a Jap car from a V8 bogan speed shop .... especially when so many Jap traders have bolt-on kits ready to go ....
In lighter news, finally found time to fit my carbon fibre engine cover and intake pipe yesterday .... and half way through fitting them my new axle-back exhaust rocked up, so I fitted that as well .... mmmm Titanium tips :cool: Has a very healthy rumble now too :down::/:(
nice Andrew. I do love V35's.
now for something different.
eyes lit i want short breaths i found dark eyelids nice breasts like summer into rough hands
oh, youll love the bit about me having to remake some of my lines.
meh, the dude i ended up with at the end knew his shit, the morons i had leading up to were pretty useless.
f**k i hate that game. got 1 bloke that follows me around everywhere, has been there for the 2 mistakes ive made since i learnt that game a couple weeks back, rants and raves about them constantly. people wonder why i have semi violent tendencies.
