Internal, Damo.
They get released to us in SA Water first. If no one in SA Water wants the job, they then get released to the public!
Most of the time, the position will be filled by someone interally, so it'll never make it out into the public.
On another note, anyone keen on joining in a track day im organising at mallala? will be a combination of drift and grip, 30 min intervals between each. $300 each, have the track or a full day, booked in for march 26th.
i dont have the cash but i do have the pink slips for my car, i win i take the money and the respect
That cafe next to the courts in Victoria Square, opposite us at SA Water... it's called Q or QC or some shit like that.
the price dosnt bother you so much when work pays for your lunch there :( meals are tasty there reccommend the snity burger, dont know how much they slug u for it though.
Sorry Luke, but Dan is right. Have a one week holiday from the forums to think about how cool midnight blue really is. 20% warning added as well.
you've been cast off the island b*tch :wave:
could we replace the 20% thing with steps. step 1 time in the corner to think about what you have done etc :D
Edited by Inline 6
A job, Boof? What industry do you want to work in?
Right now im in the plastics industry just stepped into a more engineering type of role but we were put into receivership last week due to our parent company going to voluntary receivership...So now with bub's all of 11 days away from being due i might not have a job any day now, and word on the street is there's no money for renumerations or anything...
As for where i go...I have NFI what i want to do, i enjoy what i do now problem is im not qualified engineer so i can't go anywhere with it....*shrugs* Government job would be good but don't think i'd qualify as a desk jockey very well lol!!
Ah. Off to get a haircut. Hate getting it done.
Wish I was still with the ex! She was a hairdresser :wave:
It's just most places I go these days, the conversations I have with them are just so awkward!
I'm only asking them if they've had a busy day... not their period cycle or anything.
most of the gov jobs listed are "project officer" type roles that require experience in, well, officering projects, and the like.
I am a Project Officer, have you downloaded a J&P and tried to answer the questions? You can pull experience from pretty much anything.
Ahh noice, the salaries attached to those kinda jobs is pretty attractive for someone my age. Nothing that overly interests me on the vacancies site, a couple, but im not qualified enough to meet the requirements.
lol i dunno how it even came about i didnt like midnight blue. Hey Andrew, matte black is so 2 year ago :wave:
Steve, yes got your text, just let me know when you decide if you can make it.
formal qualifications? tafe, uni?
No tafe, no Uni... just small courses here and there (like a Project Manager course. It's like a 2 day thing, cost $100 and gets you a nice certificate).
It's all down to experience and how you present yourself.
Why you little ....
/shakes fist
Yeah it will be sprayed sooner or later ....
Guest
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
