Hi guys
Today after taking my cat to the vet were on the way home and BAM! he pisses all over my passenger seat so bad its soaked through and dripped on my carpet beneth the seat.
I pulled the seat out of the car and am getting the carpet steam cleaned tomorrow.
Any one else ever had a really bad problem like this?
I think my only option is to get a replacment seat.
OMFG never take your animals in your pride and joy :spank:
https://www.sau.com.au/forums/topic/188884-help-cat-piss-in-passenger-seat/
I once took my labrador in the skyline as a last resort. He had just had an operation to have a tumour removed from his shoulder.
Dog hair and blood all over the back seats and the fronts (He doesnt like to stay still)
Drove straight to the detailing shop and had a full interior clean done, came out alright..
Cat piss does stink though. Id take the seat out and hose it down with lots of disinfectant and soap and leave it in the sun to dry.
Good luck getting the smell of cat piss out haha.. I've got doubts you'll get rid of it. You may think you do, but as soon as you leave the car in the heat with the windows up I'm sure it will re-emerge! Anyone seen that BO epsiode of Seinfeld? Lol..
Let us know how you go.
clean it as best you can if youve got a big bathtub or something soak the seat with any/all detergents in the house (or possibly the same stuff used for shampooing carpet. and then days/weeks later once the seat is dry put it back in and never never close your windows again. :w00t: i hope you've learnt a valuable lesson. Animals are food - not pets. Jokes.
Well
The cars at the detailers. Going to be there for the next few days.
Lets hope its money well spent, and the results are positive.
Those jjr seats look ok, what kind of rail do you need to buy?
Any way ill let you know how it goes.
me :) cat
purchase a spray called 'urine off' which you can get at your local vet or maybe even a pet store. it should get rid of the smell/stain. it retails at my work for $22.30, have had some very good feedback from it. no gaurantees though
next time transport the cat in a cage. u can also purchase a grill which sits on the bottom of the cage. put a towel under the grill. that way, if the cat does piss itself, the towel should trap the piss, and you'll minimise the chance of the cat sitting in it's own urine. or you could go even further and cover the car seat in towels for extra contraception
Edited by into oblivion
does that work for beer spill too :P?
HAHAHAHAHAHHAHAHAHAHHAHAHAHAHAHAHHAHAHAHAHAHAHAHHA
oooooooooooooooooooommmmmmmmmmmmmmmmmmggggggggggggggggg
HAHAHAHHAHAHA
oh dear
ok, you did the right thing by taking the car to a detailer but OMG how many people get to say that in their lifetime!?!?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
