  • Replies 49
well the plans at the moment will probably be a different exhaust and a Motec M800
Oh dear... :D
What's wrong with the current setup??
Installing a motec will devalue the car....
Don't forget there are only 20 of these in existence...
I've had the pleasure of seeing this car in the flesh at Racepace, and always hoped that the lucky bastard that buys it keeps it the way it is without raping it.
I'm shattered....
My numbers still haven't come up so I guess I missed the boat.. :P
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406208
I was talking about this car the other day. Wish it was in my drive. Having said that, it would never leave the drive and would live in a blow up protective cover.
i would leave it standard, buy a gtr thats not a z tune to mod.
Edit, Please PM me the link to pics when you get the chance. :P
Edited by BNR32t
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406229
did anyone miss this... "427 monaro". nice! your dad has some taste mate, and lucky for him some cash to back it up.
nice garage. 427 monaro and a Z-tune. easy meets west in limited run 'tuner cars'. It's a tough choice as to which one I'd have though. the monaro or the GTR. I mean, I love the z-tune, but the 427 is a pretty special car too.
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406978
Yep - before you go wrecking it with an M800 go and speak to Ben at Racepace who knows that car as well as anyone and have a chat to him about it.
Infact if you also want an exhaust go and speak to him. Best GT-R exhausts around. :)
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3407225
You're going to be changing a Z-Tune's exhaust?
You do realise its a full titanium system worth a boat load of money right? The last time I saw one sell it went WELL over $5k at auction (500,000++yen).
It screams bullshit that anyone would even consider this.
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3407933
Well my theory is its still his car so he should do whatever he wants to it. And if hes going to change stuff, at least it looks like hes not going for China gear.
But having said that, its true, how can you top a full titanium Nismo exhaust? :cool:
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3408757
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
