Engine and drivetrain specs check the current crop of Corvettes.
Floor pan is same as the VE Commodore.
I like it. It will be quick in a straight line and around a track, no doubt about it.
The interior is straight influenced from the 60s Camaros. I don't think it's ugly, heavily styled but not ugly. But I know what it is representing so I guess that makes a difference.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
