Hi all,
I remeber a thread about a week ago about ABS. Now someone mentioned an ABS light on the dash.
I have a 96 SII GTST, which apparently has ABS. On the Japanese auction report mentions ABS, etc, etc.
Now, i have no ABS light i can see come on. I have HICAS, ENGINE, Etc, etc.
Is there any way I can check if it has abs without slamming the breaks on while driving? anyone got a photo of the abs module in the engine bay?
Cheers,
Ace.
https://www.sau.com.au/forums/topic/18918-abs-again/
ABS module is on the right near the top of the firewall. Its a big metal thing with lots of little metal pipes going into the top. I only just found out what it looked like the other week myself, as mine is a series1.
There is also a control computer under your centre console glovebox
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-397323
  • 4 months later...
Sorry to resurrect an old thread but can someone provide a picture of the ABS module?
I don't have an ABS light on the dash but in the fuse box under the bonnet i have the 2x abs fuses plugged in - Just wondering if this car has ABS (1995 s1.5 (i think) R33, driver airbag, higher wing etc) but maybe the dash has been changed at one stage?
Or in non-ABS cars, do they just give you the ABS fuses cause they are feeling generous? :)
I might have to slam on the brakes to see if they lock up but I guess if I had a picture of the module I can visually inspect whether ABS is there or just spare fuses plugged into the ABS slot
Thx
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581169
Hay mate, it also same happan to me, my car 96 GTST also doesn't have ABS as well.
If u wanted to know whether u have ABS or not , u can take ur car to the garage to ask. Or try it by urself, simply drive about 60Kms, and then totally stop the car, repeat it fews times. If the wheel didn't knock while u were braking. Then u has got a ABS. But if ur wheels is locking, that mean u doesn't have ABS. Hope it could help.( If i'm wrong, plz correct me!)
Cheers
Steven
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581328
there's really an easier way guys....just pop your bonnet and have a look.......look for the ABS module similar to the one cobo_11 posted...it'll be in the upper right corner of the engine bay:D
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581342
guys as everyone here has seemed to mention...just pop ur damn hood up and see if u have a big metal block with 4 or so pipes commin out in the upper l/h corner of ur car. or just look at ur firewall at the back of the engine block...if u have two small metal pipes runnin along there then u dont have abs...but if u have 4 then u have abs...now all u have to do is follow these 4 pipes that will lead u to the big metal block which is the mysterious abs module thingy mah jig that no one can seem to find. go out now and have a look before u forget:D:D
https://www.sau.com.au/forums/topic/18918-abs-again/#findComment-581351
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
