What Size Injectors To Go For When Chasing 300kw ?
hi all, well its ssems like it has been a long slog but almost finally there, (last of the mods) had the car dynoed a little while back, (safe tune only, little over 200rwkw) as at that time i had a stock turbo and was running premium not 98 octane fuel, I have since installed a Vg30 hi flow and just waiting on the tune to switch to 98 octane, I need to know which injectors to buy to help me achive my aim of 300kw!! will the 550 sard inj do the job nicely? my mods so far include: pwr fc, Vg30 hi flow turbo, fpr, jj intercooler, ebc, when the car goes in to have the tune, injectors as well as Z32 afm will go in, thing is i have heard conflicting stories about running overly large injectors in a car that doesnt have massive amounts of power/let me re phrase that, overly large injectors can cause idiling and fuel consumption problems. with the mods i have listed what size injectors would people reccomend for me to achive my aimed 300kw?? at $760 delivered i am looking at the sards, but for $860 Delivered i could also get TOMEI 555cc or TOMEI 6 Injectors for $875 Delivered or 6x Tomei 600cc injectors - $820 delivered so what does eveyone think? will i need anything larger than 600cc to achive 300kw with supporting mods or can this be achived easily with 550cc injectors help!
550cc-600cc
But that turbo will not make 300rwkw :(
I made 277rwkw with my hi-flow rb25/VG30 combo. That included cams and extensive head porting; boost was 16psi, but higher boost settings did not make significant power increases (ie: past the efficiency range of the turbo).
I am now building up a completely new engine setup (including new turbo), which should make about 300-330rwkw; i still intend to use the 550cc injectors as my mechanic's calculations have indicated that the injectors should flow enough fuel.
sorry was editing my first post while you replied, so please review it.
On a stock rb25 i think about 250-260rwkw.
I sold that turbo to a guy, that goes to the same w/shop; on an std rb25NEO it made 270rwkw. BUT rb25NEOs have larger cams, solid lifters and probably some more engineering/power benefits over the R33 rb25.
You shouldn't have a problem running even bigger injectors because the computer is only ever going to let the injectors open up enough for the fuel it needs.
its just that i had heard running larger injectors than u need can cause problems with idleing issues
that is correct, larger injectors may cause ideling issues, ur car will run a little rough, and sound like it has cams hahaha... i think ur best bet wud be to go the 555cc injectors and if they dont do the job throw in a FPR to keep the fuel pressure up.
550's will do it without breaking a sweat, just grab a 2nd hand set and away you go, easy
^^ i wont get s/h ones, always brand new gear when it comes to my baby LOL! BTW i neglected to metion i also have a bosch040 fuel pump to go with my supporting mods
personally i would never want my injectors running at, or near, 100% cycle..
the last thing you want to run out of is fuel. they do, and will go fkn bang if you keep running them like that.
injectors are not really that expensive between different sizes now, for 300kw @ wheels i would at a minimum be using 600cc - 720cc
using bigger injectors than needed is going to be better than running ones that are just big enough. if you have your car tuned properly
when they go in you will find that you will have very little problems at all..what fuel you dont need will be returned by the fuel preassue reg.
good luck with it.!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
