Hey guys, i'd like to know what i need to get my car sounding a little better than what i currently have, i bought a new pioneer headunit (mosfet 50wx4), and 4 6" pioneer 2 way speakers (rated at 160w), i thought my car wouldve sounded much better now, how wrong could i be!.
The car is lacking bass big time, i only really want 4 speakers and no sub, and kind of like the sound from my old mans factory 2000 ford au fairmont, which is what i was hoping to acheive, but its lacking the bass big time.what do i need to make it sound good without a sub, i know of cars without sounds that have semi ok bass, which is good enough for me.
also, my aerial goes up even when im playing cd's in my r33(not with the tuner active), this never used to happen, what couldve caused this???
NO SUBS?! YOU'RE CRAZY! I WON'T LISTEN TO THIS!
Anyway, sounds like you need to tune it properly... This can take some time and requires a fine ear...
Or just turn the bass up on the headunit/amp crossover... upon re-reading, buy an amp...
Or try getting some 6x9s in the back if you really don't want a sub (you're still crazy)...
Re ariel: You wired it up wrong, you gave it a 12V+ ACC line, there should be a better on that only turns on when the radio is selected... Did you follow the diagrams in the manual and stuff? How good are you with this kind of stuff? Should be a blue wire, perhaps with a white stripe i think...
You can get small subs, like 10 inch taht fit just about anywhere, or all in ones that can fit under the passanger seat... But either way, it sounds like you're on a massive budget of about zero dollars... so i would fiddle with the settings on the head unit if it has any... after that, amp the speakers...
as above yeah get an amp to power the speakers and you probably would have wanted to buy better speakers like some higher end alpine 3 ways or focals or something to get some bass out of 6" speakers. but yeah cheapest option would be to get a 10" sub and an amp to power it. ive got a 12" sony with a boss amp in my boot. total cost $300 it puts out bloody good bass for a $300 setup. so you should be able to get a nice cheap 10" setup that wont take up much boot space at all.
Sorry to say but you are going to find it very difficult to get the same amount of bass out of these pioneer speaker as you would from a sub, or even the factory speakers in your old mans fairmont. Size is everything.
The people that get good bass with out a sub spend lots of money to achieve this.
If space is an option the cheapest option for you would be to buy a good 10 inch sub in a box.
Which of course you do want this ON because running 4" speakers you would want them crossed over no lower than 160hz because the little pissy cone will not be able to create the amount of excursion needed to reproduce anything lower than that.
I have 6.5" splits in the front, which have lots of bass (Rainbow 265Kicks). But then again I probably set aside $500 just for the installation of front splits, which included dynamat both inside and outside door skins and dynaxorbs behind the drivers too.
You might get more bass out of a set of 6x9's in your parcel shelf?
Edited by Trav33
Might be silly, but unplug one speaker while playing bassy music. If the bass increases, you may need to swap a positive and negative around on one of the speakers. They *may* be running out of phase with each other, thus cancelling each other out.
A very long shot, but i've seen this happen before.
Also check your headunit doesn't have something like a sub frequency cutoff on (SW on Alpine head units). Every time I reset my unit, or disconnect the car battery it automatically turns on the SW filter (shown as SW on the screen) and NO bass comes out of anything (even speakers it seems). I have to turn this off to get the sub going.
Fixxxer
Reason why you have no mid-bass is lack of sound deadening and quality speakers..
R33 doors are hollow!! theres nothing in them
Currently have hertz hsk splits and these have plenty of mid-bass.. just need to amp the speakers and it will sound even better..
But i understand what you mean, by that factory model ford.. Same as very other new model car.. Stock speakers sound great in them, with plenty of bass..
Edited by siddr20
If that is the size of the cross-over comparative to the speaker, then it's pretty damn big!
But otherwise, a fgood choice for nice, clear sound :)
Don't try and push too much bass through them though...
Another quick question, how the hell can we replace the speaker wire in the fronts?, cause if was to run my new splits to an amp, id like to buy some decent wirring, right now, im jst using the stock wiring.I cant see a hole around the door panel area where i could route the wiring into to get back inside the car, and run it down the side.....theres one near the edge of the door panel with a gromet(all the wiring going through), but its tight as hell, cant see anything getting through it!.
Whats the best way to run these speakers?, ive decided to just get good front splits(which should arrive fairly soon), is it worth running these splits off an amp if theyve got a built in crossover???,my new pioneer headdeck is 50wx4.
Not trying to pull a stupid amount of bass out of them, which i think you are going to do anyway...
That hole + coat hanger
buy a sub or some 6x9s or something... the front will put out good clarity, but it sounds like you are trying to pull bass out of small speakers...
thanks for all the help dude,ive had heaps of thoughts going through my mind for ages now, but ive decided on some decent front splits, and see how we go for the time being, without any additional speakers.....Im not going to run ridiculous amounts of bass through the splits (im not much of a bass junkie). Will a 6.5" speaker fit in the factory pod?, and if it does, how can i modify the pod for a bit more mid bass, i heard of diffusers do a good job?, where can i buy these though?
Mine didn't fit in the original front pods, but i can't remember if it was cause cause it was too deep or something else...
New pods had to be cut, just made them out of MDF... twas simple :whistling:
If you want a bit more bass, sound deaden the doors... 33 doors are damn empty and can sound like a rubbish can if not done properly...
Glad to hear that the "phase" suggestion helped a bit.
To be honest, my front speakers sound great in the doors... but to the point where the bass was rattling the window and other things (I went round and padded things, cable-tied, tightened bolts.. etc etc) So in the end, running the door speakers on mid-neutral and using a sub in the boot seemed like the best solution. I'm quite happy with my setup this way (which is the same way i've done in previous cars... I started out not wanting a sub when I got the Skyline)
Tweeter, mid, sub. Each do a specific job ;o)
  • 11 months later...
Maybe this might not work and maybe u have already tried it,
Have u used the loud function on the pioneer? try changin it to the highest level. It makes the sound bassy'ish.
Cheers
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
