Pics will help...
But offhand Id say its probably a heater/aircon hose.
PM siddr20 - he had the same problem (with a different split dump, not JJ) and actually had it burn a hole through the air con hose!! Not what you want happening obviously!!
i'd imagine its the aircon hose
you will put a hole in it very wuickly if its touching the dump pipe.. get your aircon line modified or bent if you can
i fitted my jj front dump about a month ago and noticed this line was touching, its just an aircon line and can be easily bent out of the way. it gave me a couple of cms clearance. all has been good since installing.
just bend it out of the way... gently of course :(
hey guys!
just recently installed a just jap dump/front pipe! some sort of a metal line resting on the top of it where it bolts up. whats this line for and is going 2 hurt touching the dump/front pipe?
thanks in advance
steve
aircon hose
if your a n00b like me, and leave it.....ud have no aircon for the summer (which is what im going through now) :rolleyes:
as the others said, u can bend it a bit to get it out of the way....
aircon hose
if your a n00b like me, and leave it.....ud have no aircon for the summer (which is what im going through now) :)
looks like i better be bending it then. i need my aircon ;)
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
