hi all,
i was just wondering about some RB engines i have seen around.
some of them have the 6 coilpacks replaced with high tension leads running to the spark plugs instead.
has the ignition module and the coil been replaced with aftermarket units? or how is this done?
any advantages other than easier to change the plugs?
can someone please advise.
ron
https://www.sau.com.au/forums/topic/19017-new-ignition-setup/
believe this is done to allow bigger coilpacks, therefore bigger spark. Very handy if you are running CDI.
Have only seen it done on a track GTR, it was using 6 ford 6 cylinder coil packs, ie, each coilpack was used by ford on the falcons to run six sparkplugs, was hooked up to its own plug.
I have been told that just by removing the cover on the stock coilpacks will aid cooling as well (of the coilpacks)
ive seen this done using the factory coils bolted to the firewall runnin ht leads to the spark plugs ona factory computer
but i dont think u can use the bosh gt40 coils with the factory igtion system coz the gt40 coils have 2 wires + and - were as the factory system has 3 wires + and - and a signal wire tryin to find out what the signal wire does at the moment
hi,
what steve said earlier sounds right by using some Ford coils to replace. I had a look in an MSD catalog and found some modules that may work for 6 cly of course, but dunno about the cost.
i took my cover off a while a go but cannot tell any different.
but it will sure cool the packs down.
the car that i saw was stock by the way, man!!! should ve had a better look!!!!
ron
Hi guys, if you are loking at more than 750 bhp then upgrading the standard coils may be worthwhile, under that it's a waste of money.
If you are looking at more than 750 bhp, then 6 individual coil packs suitable for CDI would be the best choice. No hi tension leads as they add another area for problems. On the Motec CDI equiped race cars we use Mercury outboard coils at the plugs mounted on a fabricated rail.
Hope that helps
When you look at the age of coil packs on a R32 in particular, we need to start thinking about alternative and newer methods to ensure reliability of the vehicle if we decide to own it for a few more years.
Another benefit is the ease of changing plugs. I hate that job and im sure there are other out there that do to.
I have thought about getting my hands on a crow cams amplifier pack and wiring it into the loom so it recieves the signal from the ignition pack then power is transferred to the plugs through hi tension leads?
Not really interested in adding hi tension leads but would be keen to find a cheaper replacement for when the coils die.
I guess you could resite the coil rails to mount on the rocker cover and run very short plug leads
These cars you see running aftermarket coils are using aftermarket ECU's.
Around 1 year ago, I saw an RB with I think it was a VP coil pack running high tension leads.
A few phone calls later and I was told that it is impossible with the stock ECU.
The standard coils are good enough for around 700hp so replacing them is a waste of time and money, heat soak is what kills them a CDI is a good fix for this problem as the dwell is reduced resulting in a decrease in coil heating. The standard coils have 3 wires running to them 1 pos 1 neg and the other is a ground connection to the cyl head.
cheers
Hi guys, the standard RB ignition coils are not really designed for use with a CDI. A CDI works by repeated rapid discharges from a capacitor during a single plug firing. The standard RB coils are designed for one single discharge per firing.
So if you intend to drive the coils with a CDI, then you really should use coils designed for multiple discharges. Otherwise you are not going to see the best effect from using a CDI. The cheapest/best CDI capable coils we have found are the Mercury outboard coils I previously mentioned.
Realistically I have found a very, very low percentage of RB standard coil failures. Plus good second hand ones have proven very easy and cheap to locate. High tension lead failure is a far more likely occurrence, so I avoid them. As Mort posted, over 700 bhp and I would think seriously about CDI with on plug coils, under that and its a waste of time and money.
Hope that clarifies
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
