hey guys, ive just recently dynoed my GTT R34 with a pod style filter, and boost controller running at 10 psi...I just need some advice on a few things:
1) Ive achieved 171kwrw at 6300rpm. So i was just wondering if it was best to shift gears at 6300rpm rather than up to 7000rpm as it might lose speed.
2) Is this 171kwrw the same for every gear???
3) I dynoed before with standard boost and got 164kwrw, however the acceleration on standard boost was much faster than the 10 psi boost from around 0-4750rpm. But from about 4750 onwards the 10 psi boost beats the standard boost to 171kwrw...So what i wanted to ask is in terms of speed 164kwrw car can overtake the 171kwrw in first few rpm, then the 171kwrw car can catch up from 4500-7000rpm. Does this mean eventually 171kwrw will win or it might even be a even race???
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/
Dude, when your talking 8rwkw, you wont notice it in all honesty. And i'd be surprised if anyone would ever be able to.
What car is faster will have have far more to do with the driver/tyres and so on than a couple of kw's as we arent talking about highly tuned racing machines here, which notice small changes in power outputs, we are talking about street cars which are not refined to be able to take advantages of minimalistic gains like that.
So to answer the question which car would be faster? Neither :laugh:
I'd shift around the 6500rpm mark as i assume you'll drop back into a nice mid-range.
Although running more boost i cant see how the acceleration is any different, as it should not be at all. The car will still ramp up boost the same.
If it is, then likely you need a tune with some programable management.
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3426439
oh thanks mate ;) But i figured there was quite a difference and how i figured that out was when i raced a WRX...wasn't much of driver's skills that made the difference as we did it couple of times...the few more kw's actually made a difference from my perspective BUT then again you might drive like 1000hp cars which compared to the small fries i drive may be no difference at all to you :) Just my thought..
Edited by R33Turbo
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3426819
I've had various tunes with various motors (all RB's), and honestly when the dyno has read me 6rwkw more.
This was in 220rwkw setup form at the time. 6rwkw IMO was more conditions on the day of the dyno than anything.
I honestly didnt feel it.
My times @ the strip were more dependant on my 60ft time, and every 0.1 sec made a much higher level of difference at the end of the 1/4 mile that 6rwkw would have.
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3426826
I think a point here is he has not actually had it tuned.
So it makes more power when it has more boost but becuase there is more boost the tune is screwed and he has lost power in other parts of the rev range. Is that what you mean ?
In answer to your other questions
1> shift point is complicated. You have to rev it slightly past where your peak power is but same time make sure your next gear is not left in lag city becuase you short shifted. So you really should use the trial and error method but start around 6500 rpm and see where that leaves you in your next gear.
2> No different power in different gears as you have different load levels and boost.
3> Possibly, often the smoother tune will beat the tune with higher peak HP.
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3426925
Will it be much of a difference in kw depending on which gear the tuners use for dyno? Because then why are people showing their kw@rw disregarding or withholding which gear they dynoed it at? 1 dyno could be higher than another depending on which gear the tuners used...
Regarding the 3rd question ive asked, so does it mean the higher the kw@rw it will end up beating the lower kw@rw eventually disregarding how fast their acceleration was in the 1st few rev range?
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3427656
Gear used is always 4th in a manual. Simple as that, and its a given.
Like i said, a few rwkw really is not going to be noticeable mate.
Whichever car gets the best launch off the line, will be the faster car. The best launch at the drags is critical to the fastest time more so than a 8rwkw.
Simply put - 8rwkw is NOT enough to makeup 2-3 car lengths when under full song.
Of course in the 'perfect world' the car with more power will be faster. But this is reality and whoever shifts faster/launches better etc will be the faster car on the run.
https://www.sau.com.au/forums/topic/190237-re-dyno-graph/#findComment-3427982
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
