Ok thanks. What sort of adaptor plate? See I have a Trust 550PS single turbo kit(manifold/turbo/dump/front) that I want to use on a R33GTR but as I said was meant for a RB25 so is the adaptor plate an easier/less expensive/reliable option than getting a custom manifold made?
Edited by BaysideBlue
Why not just get the proper kit.
Most Trust turbo kits for RB25 wont even go near the potential of what you could do with a proper GTR kit. Im guessing its something like a TD06-25G kit? If its T67 or larger then your cooking with gas. But from what ive seen of late TD07's are the rage on 26's in jap land.
Sell the manifold and get one fabbed up or buy an off the shelf replacement. Trust manifolds are alright quality and fetch quite a high price simply becasue of their name so you shouldnt have too much trouble moving it
Yes a TD06-25G kit, its going on the R33GTR I'm importing. I don't want more than 300awkw so not after a big single. What do you meaning cooking with gas?
This turbo should be quite responsive for a RB26 and more reliable than factory turbos. Other than that I want to keep everything as stock as possible, maybe a fmic and injectors.
I might sell trust manifold as ardie suggested if its an easier option, before then I would like to find out more about the adaptor option.
so how does everyone think of this turbo on a GTR?
http://www.slidingperformance.com/catalog/...products_id=386
Have a look at that.
Im sure you can get $500 for you trust manifold easily. Once sold get one of those.
Adaptor plates work, however.... i would rather have the right manifold.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
