Can someone please tell me why the 3071 Garrett isn't made in the T3 .82 housing ? I have been watching with interest the adventures of Mafia, Cubes, Dale FZ, and Lithium so have come to the conclusion that Dales turbo is too small and at the end of it's compressor potential. Mafia I think may be on to a good thing as would Lithium and Cubes but Cubes doesn't really fit here as the 3ltr is very different in behavior to the 2.5 ltr. Lithium is closer to the money with his setup and I'm just not sure if the lag might be too much. BUT..... The 3071 in a t3 .82 would in my opinion be the ants pants. I spoke to Morrie at Horsepower in a Box and he has a brand new turbine casting which is rated at .70 that bolts straight onto my bell mouth dump so before I go ahead does anybody think that turbine ( the .70 ) would be better on the 3076 with anti-surge compressor or the 3071 ? Looking at 250-260 without beating the intake charge to death and risking intercooler heating up too much on track days. I can get three laps in before the heat in the cooler starts to cause the check light to come on in the top of 4th gear. No, I don't want to buy a HKS 2835 as the kit is too expensive. The VG 30 on my gcg hi-flow would get me the power and for price, you can't beat it, but time to bite the bullet and go bigger.
The real reason is my car is faster than most and with the suspension changes is a pleasure to drive. I won't be selling it for some time. Besides, it would be worthless. So any ideas ? :P
https://www.sau.com.au/forums/topic/191138-3071-garrett/
  • Replies 148
If you are going to get a 3071 then bite the bullet and get the proper 3071 with a proper garrett IW housing and get your front pipe modded to suit. If you look here this is the cart you want. As you can see in the text the turbine housings are interchangable with a 3076 as it's the same turbine.
If the HPIAB turbo is different to whats shown on the garrett site then you likely have a cropped turbine version which is a bit of a nugget.
Take a trip to chipping norton and see garrett direct or even gcg at condell park, because there is a .82IW housing available for the real 3071.
Edited by BHDave
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3439684
Now, just which is the Real 3071 and yes, I will be going to Garrett as they are down the road almost. For the easiest install would the 2.75 be better or the 4" ? Realistically, what potential has this combo got ? Got all supporting mods so with .82 housing this should be ok for a "comfortable" 250-260 wouldn't it ?
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3439733
the easiest way to spot it is turbine size. 60mm is uncropped gt30. 56.5mm is cropped. 2.75 inlet is the easier to install as it is a closer match to the stock inlet size, 4inch requires a bit of mucking around.
It will easily do 250-260, it will stretch to do 275-280 i'd say.
Edited by BHDave
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3439747
I believe that at the level I am currently at, my turbo has nothing over a .82a/r GT3071R - but a GT3071R would have a fair bit over mine in terms of streetability. If you are confident you aren't going to get bored with 250-260kw, then I think you are on the money. My car is perfectly streetable, and even at the "underutilised" level it is at the moment I think it would be really really good on a track. It has an exceptionally predictable power delivery, once the thing is past its boost threshold the thing leaps into life as soon as you get on the throttle. A GT3071R could only be better :P It is nice knowing I potentially have another 100hp @ wheels of flow without changing it if I want it without adding any lag or changing it though....
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3439845
Ok. 60mm, uncropped, 2.75" inlet. This should be interesting. Simon-R32 I hope you go ahead. I 'm hoping the less inertia required to move the 71 vs 76 should improve coming on to boost. One thing I'm becoming increasingly aware of is how important it is to go no lower than .70, .73 in the turbine housing or the RB 25 will choke. now, is there any chance of someone finding a decent price or is HPIAB the best around.
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3439943
Hey guys I posted in the other thread, I'm running a GT3071R with IW and 0.8 housing. The turbo is the XTR bolt-on kit (required spacer already supplied)
The rest of the relevant mods are as follows:
Stock internals
Hybrid FMIC
Davies Craig electric water pump
Davies Craig twin thermo fans
Denso iridium spark plugs
Splitfire coilpacks
HKS exhaust cam gear(currently set to 0 tho)
Oil cooler kit
HKS turbo back exhaust and JJR split dump pipe
555cc nismo injectors
600hp tomei fuel pump
nismo adjustable FPR
Greddy profec b spec II boost controller
Haltech e11v2 ECU
Plus everything you normally change for modding the turbo, braided lines, custom piping, catch can, cold air induction etc
The car was tuned at MRC Performance in Castle Hill NSW.
I thought I'd be making around 240-250 rwkw with that setup on around 16psi.
To my suprise my tuner got 271 rwkw on 14psi :O and says if I get a better inlet manifold and exhaust manifold it should see just under 300 rwkw on 14psi! Might be pushing the stock internals a bit tho.
But anyways, there you go the GT3071R isn't half bad, the car comes on boost early at 3200rpm and pulls hard through to 6800rpm. I can post the dyno sheet if you would like, just thought you might be interested as not many people are running this turbo to my knowledge.
Cheers Steve.
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3440303
Would you do us a favour and post up the dyno sheets please. This will help with a few mathematical reviews of the results recorded. I note that the engine is internally stock, so that any airflow development work is limited to fairly typical bolt-ons.
Also, either have a look at the ID tag on your centre section, to give us the necessary info to determine which spec GT3071 you have and gain the understanding of how it performed. There are three permutations:
700177-5003, or
700177-5004, or
700177-5023
All have the same 56T 71mm compressor, though housings may differ. Using some fairly reliable data, I’ve got calculations and a map plot that says it should require about 47 lb/min of mass flow at the boost level claimed to deliver ~ 430 crank hp which should deliver ~ 270 rwkW. That mass flow is at the edge of the map, and boost increase most likely won’t equate to efficient mass flow (and engine power) increase.
Turbine performance, as I am still learning, is one of the major moderating variables of whether the compressor can work to maximum potential, or consume a fair bit of energy scavenging cylinders which are being backed up by increasing turbine inlet pressure.
Before my understanding of turbine characteristics was much developed, I had reckoned about 245 - 250 rwkW to be as good as the 3071 with hybrid OEM housing + 56.5mm rotor would reliably do on an RB25. I can see that a GT30 housing + 60mm rotor would lift that significantly due to efficiency gains.
Long explanation cut short: Zilch please supply the dyno sheet, turbo CHRA # from the ID tag and housing A/R so I can see how close to the money I am. If your dyno sheets aren’t overly “happy” as Mafia asked about, then you should smile. But don’t expect to find any magical top end gains by just running higher boost. Mid range would be another story… :D
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3440730
Actually there are five versions of the Garrett GT3071R/GT2835 group .
Just bashed this out the other day at the Silvia site but not everyone goes there .
This group of turbos is based on the GT30 turbine and Garretts 71.1mm GT35 compressor family . HKS sold all of the cropped versions and Garrett two of the cropped and the only uncropped version .
1) Cropped 84T turbine with 71mm 48T compressor 700177-1
2) Cropped 84T turbine with 71mm 52T compressor 700177-2
3) Cropped 84T turbine with 71mm 56T compressor 700177-3
4) Cropped 90T turbine with 71mm 56T compressor 700177-4
5) Uncropped 84T turbine with 71mm 56T comp 700177-23
My opinion only but the only time I'd go anywhere near a cropped turbine GT30 based turbo is if I particularly wanted a GT2835 Pro S . The cropped turbine is not a bad thing but there is a very limited range of turbine housings that work properly with it . The T28 flanged GT28 IW housings are a bodge with this turbine so avoid at ALL cost . The flange size is wrong for a single turbo Skyline anyway so no reason to go there .
Garrett most certainly do make T3 flanged integral wastegate GT30 turbine housings and the "real GT3071R" uses the matching uncropped GT30 turbine so they bolt together as a set .
I wouldn't write off the 0.63 A/R turbine housing as too small particularly on this GT3071R cartridge . To get high power (260-300) from the 71mm compressor your going to have to spin it a bit faster than the 76.2mm compressor in the GT3076R so the .63 is probably not as restrictive as you think . The shaft power required to drive the 71mm comp won't be quite as much as the 76.2mm one needs so it should spin up a little sooner and have slightly better transient response . I would think it would "windmill" a little faster than a GT3076R so you should get a bit more part throttle torque at lowish engine speeds . Cubes can give you the details of this theory .
I always thought that if I was going to bolt an IW Garrett GT BB turbo to my R33 it would probably be the real GT3071R with the REAL GT30 IW turbine housing in 0.63 A/R . I did try for a while to locate A HKS GT3037 Pro S turbine housing in 0.68 because that I think its as good as it gets for a responsive GT3071R or GT3076R single scroll turbo thats not a hybrid one off cartridge combination . As for the .63 , if Mafia can get 300 Kw from a 0.63 GT3076R which has a 500+ Hp caple compressor you should be able to get close with a 440 Hp capable one .
Remember the real GT3071R should have 700177-23 or - 5023 on its ID tag . To be doubly sure the turbine diametres are ~ 60mm x 55mm , if the turbine outlet or exducer diametre measures either 51.9mm or 53.6mm its not the real one .
Cheers A .
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3441871
Thanks for filling the blanks. :)
I ran with the Garrett branded specs but worth throwing the full range of options that come from the HKS brand too.
Frankly, going with anything other than the 0.63 A/R turbine + 60mm rotor is probably missing the best of the GT35 71mm compressor which does need extra shaft rpm to perform. If it is being spun comparatively lazily by the 0.82 turbine, then it's missing the speed to move the air mass efficiently with part throttle situations. You'd end up with an artificially high boost threshold, with no appreciable high rpm efficiency gain.
Advice I received from a Garrett engineer is that the 0.63 GT30 is effective/efficient in service applications with 400 crank hp of mass flow, so working on plus/minus 10% I'd think it to be a decent match on the -5023 GT3071.
Again though, 270 odd rwkW would be hard to improve upon without internal engine developments.
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442039
And thats the problem Dale, I don't want to spend 3,000 on a new setup and think I MAY get 250-260, I want to KNOW. Not close, that would upset me. Zilch seems to be on the money there but from what GCG have told me that turbo was $2,600. uuuuuum....no thanks. Morrie at Horsepowerinabox says his turbine housing is .70 so maybe that would be the best of both words. Trouble is, if you look at their site they have two housings, .63 & .70. Is he selling me the .63 and telling me it is a .70 ? If I go the 3076 my concern is the waste gate may cause boost creep, and frankly, if you pay attention to other sites there are far too many .63, .64 3076 combos with this problem. Look at Lithium. I really need to make the right decision.
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442099
The boost creep situation seems to result from hybrid setups; ie mismatched flow capacities between compressor and turbine, and turbine:rotor for the mass flow being specced by an operator chasing a certain power level.
Boost creep comes about because the turbine + wastegate vent can't pass the mass flow that the compressor is able to supply.
You'd need to ask inabox where the designs for their castings come from. At a guess (and purely uninformed here, no aspersions cast on them) they may have sourced a foundry that copies the Nissan OEM housings so they are selling brand new gear. I noted that those housings are a bolt on which includes the 6 bolt/stud dump flange, which is different from the GT30 family. If that's the case, then you end up with a hybrid (which is what mine is)which has limitations you need to understand/accept before spending the $$. That's why I've explained my thoughts and the research that's behind the opinion.
Mix n match can be a performance and economic gamble, and I believe in doing the homework beforehand. My hybrid performs exactly to expectations and predictions because amongst other things I measured the OE spec impellers against those of the cartridge I selected (side issue). BUT I went through the same agony of working without precise knowledge/experience. Fortunately you have Simon R-32 and Zilch* doing the work ahead of you
The -5023 CHRA combined with a 0.63 IW GT30 housing has the balls to efficiently get you to the nominated power target, but very little further. In a similar vein, you'd see that the Skyline spec HKS GT-RS comes with the 0.63 housing but not the 0.86. The extra flow capacity in that instance equates to no extra useable power, but takes away response.
If you wanted to run past 270kW, then the 3076 would be a better deal. And my opinion is that if you want a free-flowing 260kw that didn't give big heat build up on track work, then the 3076 is still the better deal. But that's the performance trade off you've got to look at when deciding priorities. Both the -5023 3071 and GCG Hi flow are very good units in certain applications.
If your #1 priority is hammering around tracks lap after lap then you could do better than either of those two. Then I'd probably follow Lithium's lead. But you'd want to be looking at other aspects of vehicle performance then eg. brakes, which will also take a hammering.
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442226
Hey guys I've located my camera so I'll post the dyno sheet for you sometime today, as for the ID tag, I cannot see it just by looking into the engine bay and I am no mechanic so I'm not too sure how to remove everything that is in the way(turbo is low mounted i'm afraid). Didn't want police hassles so went the low mount. I'll keep trying tho, might be able to get under the car and find out.
Oh and skylinecouple, the turbo cost me $1405 plus $300 additional for all the braided hosing I needed, from GCG in NSW :rofl:
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442579
The real GT3071R (700177-5023) can easily go beyond 270 Kw / 360 Hp , if you go all out with them theres no reason why you couldn't screw 400 Hp / 300 Kw out one and that not the absolute limit either . Read the compressor map and look at the turbine maps as well .
Out of time cheers A .
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442605
And there's the rub - to do so it's back to the money tree.
Sure, more could be extracted - but it's going to cost. Airflow development with manifolding, cams, valves, springs, porting etc will improve engine efficiency and get more from the turbocharger. Freer breathing and higher engine revs may well produce the goods. But the guy's comments are tied to some budgetary constraint.
Having read the compressor map, and checking what people are actually getting, and running plenty of maths, I'd say the comments aren't far off the mark particularly for a mechanically stock RB25 using stock manifolding. 270 should be about top whack. Maps for the GT30IW housings haven't popped up that I've seen, but if you've got them please forward through the links or a copy.
Just providing some clarity to the original question/application for the vehicle, at this stage I'll stand by the comments from yesterday. Higher average engine speeds/loads for regular use on a race track would probably see Lithium's setup a good/better thing. For more regular road use the -5023 3071 + 0.63A/R is probably better at that power point. As usual it's a case of priorities / application / budget. Without the budget to play with engine internals and manifolding, the 3076 will take him further should he want it. As always, more than one way to get a similar (not same) end result.
There are obviously a couple of punters in the throes of going 3071 so let's hear from Zilch* and Simon-R32 with real world results. Dynos are nice, but as per comments by Mafia in another thread, let on-road or on-track experiences fill the pages behind the cover. :rofl:
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/191138-3071-garrett/#findComment-3442713
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
