This thread along with Mafia's and Lithiums have given me a great deal more knowledge on turbo choice (mind you alot of disco's essays still go over my head) so cheers guys.
I'm hoping that we can get some decent results of a real GT3071R .63 A/R on an RB25 soon, as I'm looking at this turbo as a real option for a mainly street driven, stock bottom end RB25. However if the guestimates of only 250-260 are correct I cant see the benefit of choosing this turbo over for example a GCG hiflow with either RB25 or VG30 housing. The cost would be much greater for the garrett when you sort out the lines, fittings, custom dump and intake. So my question is, if 250-260 is what this the Garrett is limited to then why bother?
Now, does anyone think that the GT3071R .6 could pull 280rwkw on pump fuel, stock manifolds, possibly cams? Or would the .8 be needed? Discuss
Finally does anyone in vic have a GT3071R equiped RB25, and feel like showing me what its like on the road? Would be much appreciated.
  • Replies 148
I agree Cubes but even then you have to push them. My GCG hi flow is useless at 220kws 17.5lbs boost. 6 different tuners and a couple of grand wasted, I'm over it. 3071 .82 here I come.Can somebody access ATP turbo and give me their honest opinion. There is two different .82 housings. One is the Garrett but the other is like a flat machined housing with the waste gate hole and then you buy the flapper and v-band module separately.
Garrett IW FTW. Don't buy the other crappy 5bolt ford style.
The Garrett IW looks near identical to the XR6T IW design; but slightly improved. :D
Be sure to run with a well designed bell mouth dump as splits have a tendency to creep on the GT30 Garrett IW housings.
Better be safe than sorry.
Besides if boost levels are identical (of which they generally are not when running a split vs bell) if the split is plumbed in there's no difference in power. Have it screaming to atmo then yeah there is a slight power benefit. So back to back on the Dyno results have shown.
Yeah, I changed from a split to a bell on my hi flow and gained two kws, woo hoo (sarcastic). Just kidding, I've always believed the bell is a far superior design. No resistance to flow. So as a final order I'm getting the 3071 IW non cropped 60mm turbine with 2.75 comp. inlet. That inlet should make plumbing easier. Now, this should make 250-270rwkw and boost earlier than the 3076, ok ? Please tell me this is right. I can't believe how big a decision this is.
As said / shown before - outright boost threshold the GT3071R seems to have nothing over the GT3076R. MAYBE (you'd have to go in both back to back) the GT3071R might have better part throttle behaviour, but I am serious when I say mine is really really nice to drive. You can tell its down on torque below 3000rpm but who drives hard there and expects to go fast aside from people with 5000rpm redlines?
Got a vid on youtube of a run from the drags this weekend where I managed to badly bog a launch with the .82a/r GT3076R racing a fairly mild R32 GTSt, gives a reasonable impression of how it pulls from low revs in 1st I think:
From what i have seen on 2 sr's with proper 3071's, the response really isn't far off gtrs/2871 thresholds.
Same goes for the only rb25 with 2835pros i've been in. That thing was making 1 bar a little over 3 grand in 3rd. Admittedly it's the smaller turbine and arguably better hks housing, but it is a .68 as opposed to .63 garrett so there's a bit of a trade off there. It took next to no throttle input to hear the thing spinning up
It's unfortunate that dyno print outs of boost often don't match what we see on the road. And transient response is something you can really only experience by driving. I still believe the 3071 is the street turbo to have and (as i've said before) if my old t3/4 nugget ever dies horribly i will be getting one.
OK, first thing Monday I'll be putting the order in and it should be here next day. I'll try to make a story out of it, lots of photos. I'll get all the fittings over here but the actuator from them. Though I have seen a beautiful machined actuator on another site but can't remember where, damn. They should have a flange and new bolts, studs. Can anybody think of anything else ?
Will be keen to see the results..
As for measuring the turbo's response. Maybe pick an rpm; say 4000rpm as it should be well and truley making all its boost by then.
Second gear stomp on the throttle. Third gear at a private track only. ;)
By using a video camera on the dash that also shows the boost gauge you 'should' be able to see a slight difference in response.
Definitely agree re dyno print outs not showing the full thing, however showing my car bogging and recovering and destroying an R32 GTSt with stock turbo even by the end of first gear has to indicate somehow how quickly the thing builds? I think the GT3071R would be brilliant, and a bit better than the GT3076R for streetability. On the flipside its nice knowing I have 270rwkw and can EASILY go way past that. I think people are describing of GT3071R/GT2835s what I get with mine, ie - can hear the turbo spooling at minimum throttle in the 2000rpm range cruising around town. Throttle behaviour is very NA, etc. I'd *LOVE* to have an opportunity to drive a GT3071R and GT3076R turbo'd car back to back and see the difference actually.
If you are SURE you don't want more than 270rwkw, and can live with changing turbos if/when you change from the mindset of "My car is at the quick end of a mildly modded car" to "my car is at the slow end of a well modified car" or are pretty sure you won't change to that mindset then the GT3071R is the one ;)
Edited by Lithium
Good enough then, I'll get flanges from there just in case. No need to worry that way. Yes, 250kws will be just fine, 270 a bonus. Getting back to my original post, I want to be able to run more timing with the cooler intake charge which I can't do with the high flow for whatever reason. Is it a dud ? who cares, it's gone. Will take a couple of weeks to get everything together as in lines and stuff but a new intake pipe, silicone connectors, clamps and a large air cleaner to help it breathe. Was always going to make a new air box anyway so may as well do it now. Bare in mind I'm a bit of a fussy old bastard so all has to be right before the final tune.
As an aside, has some of you older posters remembered when a hi flow was just the ants pants ? Now there are so many choices, fantastic. I can still remember Martin Donnen putting a GT25 on a R33 and proudly gloating of it's 210kws.
Hi skylinecouple , an alternative to ATP is FullRace Motorsport in the US . Its run by Geoff Raicer and he's had lots to do with the real GT3071R and GT3076R . He's put some time into RB25's and 26's though most of what they make or sell is for Evo Lancers/Subarus/Supras because they are available in LHD .
He would be able to give you a much better idea of their characteristics on an RB25 than ATP which is really just a box up and sell operation . I don't know if he offers the GT30 IW turbine housings but it would be easy to ask him via E-mail . If he's been there with a std manifold he may even be able to supply the oil and water lines .
Your call but I think he's the most unbiased person to talk to about turbo systems because he's genuinely interested from a mechanical engineering point of view . If you explain up front that single scroll is all you want and need the integral gate GT30 housing he'll tell you the pros and cons of this system and the choice of turbo .
Search FullRace Motorsport for the E-mail or if you can't find it lets know and I'll PM you later .
Cheers A .
Thanks Disco, will do that right now. Damn it, keep thinking about the 3076. If boost comes on too early with the 3071 then it will be wheel spin city. But what if the smaller 71 comp. wheel needs to really get spinning as in lots of revs to move enough air to make the torque and power I'm after.? Shit, double shit.
Very informative discussion. I wish i had time to get away from uni studies and really look into this stuff and contribute. My stock turbo has started making some 'interesting' noises.. i was leaning towards the GT-RS kit and blindly trusting HKS's engineers (probably a safe bet) but reading this makes me reconsider.
Out of interest, do you guys just estimate volumetric/mass flow rates and efficiency (etc.) for number crunching? I notice the Garrett site has some basic information (although non-SI units frustrate me, i'm tempted to 'translate' their site :whistling:).
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
