Hi, I am new to the forum and would like to know if anyone has destroyed their turbo on a Skyline? I have read a lot about not putting the boost over 12psi, but I am wondering if anyone has done this and caused damage, or whether it is just a myth. I know there has to be a limit at some point, is it 12psi or are there people out there running their stock R33 turbos at 14psi or higher?
What are your stories of disaster.
https://www.sau.com.au/forums/topic/19118-have-you-destroyed-a-turbo/
Mine was running at 13psi quite happily turbo wise, although it was starting to ping a bit too much so had to wind it back to 12psi.
12psi I'd say is perfectly safe as long as you have a good tune and decent FMIC. My high boost has been that or 9 months or so with no adverse effects and some pretty hard driving occasionally. Depends whether its a series 1 or series 2 turbo.
As mine is a daily driver i often just run stock boost to and from places, so i wouldn't say i run 12psi all the time. People will also argue whether 10-11psi is more optimal in terms of overall performance too.
I have a R33 Series 1 and have been running 14psi for around 2 1/2 years now. The only problem I have had is the turbo sucked in and ate the rubber bung that the car yard put on to block the Bov return hose when fitting the atmo venting BOV. The same turbo is still on and going strong.
The previous owner of my car destroyed the stock turbo doing 15psi on his daily commutes to brisbane...tortured, replaced, and hi-flowed it in the end...saved me some big money :)
It runs 10psi now for daily driving, but can go up to 18psi, no sweat. Right now, that figure is a little too far fetched though
Skylines have been found by a lot of people to make better, more 'useable' power on around 10-12psi. Note 'useable'... No point running more boost if it aint doing much or downgrading performance and reliability. The fact of the matter is if you are going to boost, you need to mod and free up the airflow so that it is actually worth boosting in the first place. You'll find obviously that if you run a stock skyline on say 12psi, then have another with a cooler, exhaust, filter and tuned on 8 psi it will run a heap better and harder than the 12psi stocky. Boost does not just = power.
R33's really need an aftermarket ECU to take advantage or should I say unlock some decent power.
200rwkw isn't bad considering its a stock turbo.
The FMIC and ECU make a big difference to the R33's.
R32's pitty its not the same for the R32's. :)
Over 10-12psi the stock ECU starts doing strange power dip things.
I aren't running a computer now with my big turbo, cooler, exhaust blah blah and it still runs pretty damn well considering, however am expected to pick up around 25rwkw from computer they reckon, so on about 15psi tuned they said i can look at around 235-240rwkw which aint too bad :) But yes they do need a computer to run well, without one they jsut eat fuel and run very rich. Not good on the wallet believe me ha ha.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
