Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey ppls,
Due to other dyno days being held around the same time SA/SAU usual holds their the Annual SA/SAU Dyno day hasn't been held. Its great for a checkup of how the cars running and mix it up with a few other SAUer's.
DETAILS:
BOOSTWORX - 57 Boothby Street, Panorama
TIME: Saturday 8th of March - 10:00am :- So get there 10mins early POSTPONED
The cost of the dyno day is $30 for 2 dyno runs and a print out.
A BBQ and refreshments will be provided charged very reasonably per snag and drink
Please do note there has recently been a little hoon activity within the area (which is believed to be related to the TAFE); Boostworx has been targeted as the possible offender; so please no burnouts or hooning through the sidestreets.
The plan is it will also be the first day of accepting SA/SAU club memberships which will be cams affiliated.
No prizes etc as the dyno runs are provided at cost - Makes it fair for the near stockers.
There's no limits on what cars can be run on the dyno; bring your old banga for a laugh if you wish. As long as your an SAU thats all that matters.
So.... Who wishes have a run on the rollers on the day and possibly buying a snag or two?
01. Darkhorse - PAID
02. Vietorious - PAID
03. Salad - PAID
04. RB_Man - PAID
05. matty_31 - PAID
06. Nightcrawler - PAID
07. Dangerman4 - PAID
08. rd-runr - PAID
09. sambo33 - PAID
10. RB25DETS2 - PAID
11. 93R33 - PAID
12. wegs - PAID
13. J_Red33 - PAID
14. 180or200- PAID
15. Hotwire
16. Deluxe
17. AfterGlo
18 32_4whore
19. Heslo
20. Advent34
21. bezender
22. rad510
23. writeoff
24. dnbutts
25. AFTDRK
26. ryanrb25
27. gzilla
28. barricade
29. gtrkiet
30. natoe aka slw 031 - PENDING
31. SICKR33GTS-T- PENDING
32. Cubes - PAID
Now accepting payment to secure your place and choice of when you wish to run.
Remember its cooler in the morning. :P
We have the minimum 10 upfront payments to go ahead; if you wish to secure your spot and have a choice in when you wish to run get your payment in.
PM me for bank deposit
TIME: 8th of March 2008 - 10:00am so get there 10mins early.
AND FOR THE RESULTS...
https://www.sau.com.au/forums/topic/191361-sasau-30-dynobbqclub-day/
  • Replies 326
Posted Images
Will this be at Boostworx again? Is January an ideal time to run a dyno day? It will probably be pretty damn hot. I'd say April/May would be better although with current climate patterns - or lack there of - it may be cooler in January. I'd prefer the 19th as I usually have something on Australia Day.
Yes It will be at Boostworx again. Boostworx have the best price for a dyno day.
Myself I'm not too keen on spending $50 for a power run that some of the other dyno operators are charging when all you receive is a laminated dyno sheet with possibly a picture. GW does both 2wd and 4wd $40 and $50 respectively but $10 is $10.
I feel $30 is quite reasonable. A BBQ and Cold drinks will be available; Boostworx also has evap aircon so there will be plenty of air movement.
If the weather is possibly hot/warm it could be a really good time to hold a dyno day depending on how you look at it.
Its always good to have the car on the dyno during hot weather as you are able to find out how it runs in such conditions.
Is it pinging. Is it safe to give it a bit of a boot during hot weather?
So for those of you that don't have the car run up both in cold and hot weather it will be a good chance to see if the car is running well.
However... If the majority would like the day to be held a little later by all means it can be done. :P
I personally don't mind the idea of a warm dyno day as its a good check up.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
