Dyno Day
67 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 326
Posted Images
lol.
I'll have a little run about banga by this dyno day so I might run that up as well.
Not sure what to buy. Thinking about an old 5speed CA20 Bluebird, reasonable sized, good on fuel and go fairly well for what they are. Not many around at the moment. Not sure what they go for either.
yeah Joel Bluebird ftw there great cars and they don't die plus there a 2lt ;) sr20det drops straight in or is that a little trouble the CA18det drops straight in my preference is sr20 :P TRX for all the options :D
won't put myself down for sure at the moment, not quite sure whats going on with work ect.
knowing my luck my car will break down in the middle of a run. If anything i'll come down and have a look and a bbq
lucky schutzenfest is the week before
Edited by Whiplash
hey~! sounds good. with the plenty of notice, i should be able to come down~!! hopefully i'll get a few mods done by then, and will be my first dyno day~!!
put me down plz~!
cheers~!
I should be back from my holidays in time to come check it out & sign up.
there is a Delete button next to the EDIT button
Think that option only appears for donators unless it's been changed since the upgrades.
No probs Simon. Keen to check it out. :P
Hillzy,
So your currently not driving your car?
If its going to blow up it will blow up on the road. If your worried about running it up on the dyno definitely do not give it a boot on the road as the road is not a controlled environment; you can't hear or see it pinging so you keep your foot in to it and BANG! :)
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
