Hey
I am looking at getting a basic custom boot install done in my R32.
I have all the audio gear and have run all the wiring so all I need is the fabrication of the actual sub box and panels, as well as the carpeting.
Just wanted to know if anyone can recommend a place which does good work?
I called a place in Melbourne and they quoted me $500 for a custom sub box and panels, which I thought was a bit steep as I have already done all the wiring and am supplying all the audio equipment.
Anyways if someone could recommend a place they have used/seen work done at, it would be much appreciated.
Audio gear to be installed is 2 x amps and 2 x 12" subs, just need fake floor, and dual sub box, and side panels all carpeted and installed in an R32 boot.
Thanks,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/191474-custom-boot-install-r32/
$500 Steep.
You gotta be kidding me mate. Panelling and trimming takes time and running your cables only takes an installer a half an hour at the most.
Sorry to say but if u got quoted $500 take the offer, because custom boots normally end up costing thousands.
$500 Steep.
Second that
I am getting a basic install done next week at a cost of $2500
I am supplying all wiring/amps/sub/sound deadening and I was quoted for a very basic install (two amp racks built into a false floor and a MDF sub box) all flat panels, no fibreglass etc with just a plexiglass panel showing each amp.
$500 Steep.
Nup, $500 I believe is still a bit to much for the work I need done.
I understand that labour takes time + cost of materials, but $500 was a minimum quote and I'd rather just do it my self or get it done privately if I'm paying that much.
Second that
$2,500?
Well judging by what your getting done that seems like a straight out rip off, considering I was quoted a minmum of $500 for pretty much the same work.
Edited by abu
mate clearly you don't know much about custom installs... I'd jump at gettin it done for $500.... like seriously think about the time involved let alone materials and stuff...
if u wan2 spend less than that do it yourself...
$2,500?
Mate there is almost that just in a sub box alone
Then plexiglass is not cheap
Sound deadening is around the $300 mark for installation
Painting the installation $200 odd
Boot install is between $800-$1500 including amp racks, then on top of that is sub box and sound deadening.
Most shops charge on average $70-$100 per hour plus materials, I would like to see quality work done , from start to finish for $500.
FHRX is doing my car - i dont like cheap dodgy crap in my car.
$2500 is reasonable considering the time, and quality finish I am after.
Did you get your quote from autobarn?
Paid $1400 for mine... Was actually a pretty good deal, when i got it back, I just stared at it, and it wasn't even finished :P
I still love the look of it and it has a little bit left to finish too :)
If it had cost me only $500, I would have been f**king ecstatic!
I took it apart as soon as i got home, had a look at it, realised that if i had tried to do it (my original plan) I would have been at it for well over 3 months just trying to figure out all the tricks and skills they used... I was really impressed at how easily it all came apart... i was scared shitless at first... It looked so complete, I figured it would take me ages to get it apart and back together :)
But I asked for easy accesability/install/uninstall, and that is what I got :)
$500 - are you kidding !! FFS take it! (dont bitch about hte quality though.) hell I wouldnt even look twice at that for under $1500.
for the $500 you want me to supply MDF, CARPET,VINYL,PERSPEX and time - ahh -- NO!
If you(yourself) have the wiring part coverd....Just find a good local cabinet maker(what i used to do) to make the boxes,cut out holes for your subs,mount brackets to hold your amps....its just time consuming.
Done & Done!
You get what you pay for, so for $500 you can't expect much. That'd be basic materials (MDF+carpet) and a couple hours labour only?
Well basically yeah, that’s all I was after.
No glass or perspex and shit, just a basic install for 2 x subs under the parcel shelf in custom box, 2 x amps on the floor with fake walls and floor.
Labour + MDF + carpet = $500, thats what I'm trying to price up.
The place that quoted me is a well known Audio shop, and they do very quality work from what I have seen.
But like I said, starting price was $500, so could be more depending on specifics such as perspex and glass additions.
Done & Done!
Yeah my uncle is a cabinet maker for JAYCO carvans, so free MDF and cutting.
Will just need to pay for carpet, glue etc. Thats what I have always done in the past, but this time around I CBF as I am working full time Monday - Friday and don't want to spend weekend after weekend getting a boost install finished while the car sits in the garage taking up space. Plus I will give up half way :D
Well thats not a custom boot is it.
Well it's not stock is it? Making it custom!
Edited by abu
I don't want any fancy shit with neons and glass and crap, just want a custom box under the parcel shelf with 2 x 12" subs, and fake walls and fake floor with 2 x amps on the floor.
All carpeted and mounted neatly.
Edited by abu
Come to Auto Salon to see it...
Only a very small handful of people have seen it yet... and it's not finished technically...
Not that keen to see it, plus your in NSW and I am in VIC...
Thanks anyways.
Edited by abu
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
