  • Replies 626
Posted Images
LIST OF MODIFICATIONS
Car Make:
Nissan
Car Model:
R32 GTS-T Chassis
Power Options:
Power Windows, Power Mirrors, Power Door Locks, Power Steering, Air Conditioning, Rear Window Wiper, and among others I might have missed+
Mileage:
96,xxx KM’s
Engine & Driveline:
Dyno’d & Tuned by Kinetic Motorsports: 402.8WHP @ 14PSI / 1 Bar (Currently using 1 Bar wastegate spring)
RB25DET Swapped from an 1994 R33
MINES Tuned 300ZX Z32 TT ECU
ATS Twin Plate Carbon Type R Clutch
- Keeplabs Reinforced / Welded Clutch Pedal Bracket
Aeromotive Fuel Pressure Regulator
Aeromotive Liquid Filled Fuel Pressure Gauge
Greddy Hi Polished Intake Manifold
Greddy External Oil Catch Can
HKS SSQV BOV
HKS Type S Front Mount Intercooler
Genesis Racing Battery
Garrett GT30R Ball Bearing Turbo Hi Polished
- GT30-11 with a .64 A\R
SPLITFIRE Ignition Coil Packs
Tial Wastegate 38mm
- Externally Dumped with Custom Screamer Pipe
Tomei Short Shifter
Custom Top Mount Stainless Steel Exhaust Manifold
Kinetic Motorsports 440CC Injectors
Keeplabs Custom made Billet Top Feed Fuel Rail
Keeplabs Custom 90mm Q45 Throttle Body
Keeplabs Custom made One Piece Driveshaft
Keeplabs Custom made full Intercooler Piping
Keeplabs Custom made 3” Downpipe (Heat Wrapped – 1 02 bung, 1 extra bung for Wideband)
Keeplabs Full AN Fittings,
Keeplabs Custom Stainless Braided Fuel System
Keeplabs Custom made “Dropped Down” Aluminum Battery Tray
Keeplabs Custom “Hidden” Fuzebox
Keeplabs Custom “Hidden” Z32 Air Flow Meter (Looks like it’s running Standalone with NO AFM)
Keeplabs Custom Fender Wire Tuck (Prevents shredding wires due to extremely low ride height)
Keeplabs Custom made Turbo Inlet Pipe w/ K&N Race Filter
Keeplabs 3" Stainless Steel Catback Exhaust
- 3 Inch Straight Through From Turbo
Walbro 255 Fuel Pump
Wonder Hicas Eliminator
Removed: Hicas and All Associated Lines / Hardware
Suspension & Wheels:
ESSENTIAL Subframe Metal Bushings
Tein HA Coilovers (Can be substituted for 5000km new Cusco Zero-2 Coilovers; trade + cash)
Mines Front Strut Bar
WORK VS-KF
- Custom Rivet Color (Black)
- Custom Gold & Black WORK Centre Cap
- 17x10 front
- 18x10.5 rear
- Kumho Ecsta SPT
-225/45/17 Front
- 235/40/18 Rear
WORK lugnuts
WORK Valve Stem Caps
Electronics & Interior:
Apex'i SAFCII
- Keeplabs Custom Mounted in Glovebox
Apex'i AVC-R Boost Controller
Compustar Pager Alarm System ( Immobolizer + other goodies)
CUSCO Safetly 21 7 Point Roll Cage
DEFI BF Series Boost Gauge
DEFI BF Series Oil Pressure Gauge
DEFI BF Series Water Temp Gauge
DEFI Controller Unit II
- Keeplabs Custom Flush Mounted in Dash
Focal Speakers All Around
- Doors and Rears
JIC MAGIC Red Alcantara Seats (x2)
- Momo Sliders (x2)
- Keeplabs Custom made Low Mounting Brackets (x2)
Pioneer AVIC-D1 Navigation
Takeda Custom Black Leather / Red Stitching Shift/E-brake Boot
Nardi Perferated Leather “DeepCorn” Steering Wheel
Nardi Classic Shift Knob
Body/Exterior/Lighting:
BlitzGear Pin Stripe Graphics
BlitzGear “Keeplabs” Crest Graphics
PRIME HID Kit 7000K
Paint Job Color: Tri-stage Alsa Corp Ice Pearl Black
Keeplabs rolled / pulled fenders
- 30+ mm over
Final Konnexion First Contact Front Bumper
Final Konnexion First Contact Side Skirt
Final Konnexion First Contact Rear Bumper
GTR Aluminum Hood
GTR Grill
Edited by abu
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
