  • Replies 626
Posted Images
LIST OF MODIFICATIONS
Car Make:
Nissan
Car Model:
R32 GTS-T Chassis
Power Options:
Power Windows, Power Mirrors, Power Door Locks, Power Steering, Air Conditioning, Rear Window Wiper, and among others I might have missed+
Mileage:
96,xxx KM’s
Engine & Driveline:
Dyno’d & Tuned by Kinetic Motorsports: 402.8WHP @ 14PSI / 1 Bar (Currently using 1 Bar wastegate spring)
RB25DET Swapped from an 1994 R33
MINES Tuned 300ZX Z32 TT ECU
ATS Twin Plate Carbon Type R Clutch
- Keeplabs Reinforced / Welded Clutch Pedal Bracket
Aeromotive Fuel Pressure Regulator
Aeromotive Liquid Filled Fuel Pressure Gauge
Greddy Hi Polished Intake Manifold
Greddy External Oil Catch Can
HKS SSQV BOV
HKS Type S Front Mount Intercooler
Genesis Racing Battery
Garrett GT30R Ball Bearing Turbo Hi Polished
- GT30-11 with a .64 A\R
SPLITFIRE Ignition Coil Packs
Tial Wastegate 38mm
- Externally Dumped with Custom Screamer Pipe
Tomei Short Shifter
Custom Top Mount Stainless Steel Exhaust Manifold
Kinetic Motorsports 440CC Injectors
Keeplabs Custom made Billet Top Feed Fuel Rail
Keeplabs Custom 90mm Q45 Throttle Body
Keeplabs Custom made One Piece Driveshaft
Keeplabs Custom made full Intercooler Piping
Keeplabs Custom made 3” Downpipe (Heat Wrapped – 1 02 bung, 1 extra bung for Wideband)
Keeplabs Full AN Fittings,
Keeplabs Custom Stainless Braided Fuel System
Keeplabs Custom made “Dropped Down” Aluminum Battery Tray
Keeplabs Custom “Hidden” Fuzebox
Keeplabs Custom “Hidden” Z32 Air Flow Meter (Looks like it’s running Standalone with NO AFM)
Keeplabs Custom Fender Wire Tuck (Prevents shredding wires due to extremely low ride height)
Keeplabs Custom made Turbo Inlet Pipe w/ K&N Race Filter
Keeplabs 3" Stainless Steel Catback Exhaust
- 3 Inch Straight Through From Turbo
Walbro 255 Fuel Pump
Wonder Hicas Eliminator
Removed: Hicas and All Associated Lines / Hardware
Suspension & Wheels:
ESSENTIAL Subframe Metal Bushings
Tein HA Coilovers (Can be substituted for 5000km new Cusco Zero-2 Coilovers; trade + cash)
Mines Front Strut Bar
WORK VS-KF
- Custom Rivet Color (Black)
- Custom Gold & Black WORK Centre Cap
- 17x10 front
- 18x10.5 rear
- Kumho Ecsta SPT
-225/45/17 Front
- 235/40/18 Rear
WORK lugnuts
WORK Valve Stem Caps
Electronics & Interior:
Apex'i SAFCII
- Keeplabs Custom Mounted in Glovebox
Apex'i AVC-R Boost Controller
Compustar Pager Alarm System ( Immobolizer + other goodies)
CUSCO Safetly 21 7 Point Roll Cage
DEFI BF Series Boost Gauge
DEFI BF Series Oil Pressure Gauge
DEFI BF Series Water Temp Gauge
DEFI Controller Unit II
- Keeplabs Custom Flush Mounted in Dash
Focal Speakers All Around
- Doors and Rears
JIC MAGIC Red Alcantara Seats (x2)
- Momo Sliders (x2)
- Keeplabs Custom made Low Mounting Brackets (x2)
Pioneer AVIC-D1 Navigation
Takeda Custom Black Leather / Red Stitching Shift/E-brake Boot
Nardi Perferated Leather “DeepCorn” Steering Wheel
Nardi Classic Shift Knob
Body/Exterior/Lighting:
BlitzGear Pin Stripe Graphics
BlitzGear “Keeplabs” Crest Graphics
PRIME HID Kit 7000K
Paint Job Color: Tri-stage Alsa Corp Ice Pearl Black
Keeplabs rolled / pulled fenders
- 30+ mm over
Final Konnexion First Contact Front Bumper
Final Konnexion First Contact Side Skirt
Final Konnexion First Contact Rear Bumper
GTR Aluminum Hood
GTR Grill
Edited by abu
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
