Saw nice 4 door gun metal grey heading inbound on loagan rd waterford ~7:30pm followed him all the way until he turned off just before kingston.
Plates were MI BABY, had HUGE zaust, and pretty sure it was manual as every time I changed gears he did too?
Hey yall,
New skyline owner in Brizneyland.
Had my 1995 R33 GTST black (really dark grey) M-spec manual for about 3 weeks now, it was worth the long wait. (see my AVTAR)
Thanks to Shane from Southport for being a great bloke throught the sale, even after looking at 12 skylines I did not see one that even close to this one.
Plates XXXXXX, I haunt the Fairfield / South Briz area, give me a wave if you see me around.
I used to drive a maroon VL nizmodore with two White pony stickers on the rear, may jog the memory of a few skyline owners I tried to race over the years.
anyone know of a FAKE r33 GTR, silver, cant remember the rego... i will racing him just coming out of the valley near royal bris hospital. i told him i didnt realise it was a gtr and he told me it was a fake!! i lost respect for the guy, right there and then!!. nice car. didnt need the GTR badge to impress.
i got my arse kicked by the way... but he was running 15psi
later
by the way this is MACKY
just on my mates profile.
also we are going out cruising on thurs night
my first time!!
where the spots to go??
who do i look out for?? rego's etc and names to rego so i can say HI!!
thanks all
MACKY
Hey Guys, I have had a Skyline for about 10 months now, I only just found out about this site, I live over the south side. You will really only see my line on weekends as I drive the company car on weekdays ( rack up the k's on that). If you see me give me a wave or stop and chat I will always talk to people. Car is a black R33, with a stealth (drift king) wing, 18" alloys, 400r side skirts and stuff knows what the bar is called. Thanks to the guys at jet speed for that stuff. oh by the way the new 192kw holden VZ are still slow!!
I drive in and out of Logan city all the time and saw the stagea with the R34 front, and stalked him into the loganlea train station car park, had a chat with him, he is an awesome bloke, those pics that erin posted somewhere of it DO NOT DO IT JUSTICE!!! The owner's dad is a member here and told him bout the MSC III but he didnt know as he was dropping a RB26 in it fairly shortly and didnt know if it would be runable by then, but he said he would definalty do his best.
But still OMG it looked FREAKIN AWESOME!!!!! And the owner is a top bloke :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
